2002 DS Electric Window Problem - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Sep 9th, 07, 09:22 AM   #1 (permalink)
My 2002's driver's side window has been working slower and slower. Recently it acts as if it's popping a breaker. It moves about 4" and then stops. If I wait 30 seconds or so, I can move it another 4" and so on until it is closed.
What's strange is that even while the driver's side window is not functioning, the passenger's side works fine leading me to believe the breaker is ok.
This afternoon, I'm going to take some amperage measurements to see if it's a binding issue. I should be getting a new service manual in the mail soon. Until then, if any of you have dealt with a sluggish electric window, I'd be curious what you found out.
dnult is offline   Reply With Quote Quick reply to this message
Old Sep 9th, 07, 09:56 AM   #2 (permalink)
Re: 2002 DS Electric Window Problem
It sounds like your window motor is going bad. My understanding is they will draw more current when they are going bad as they try and push the heavy window...this results in kicking the breaker. Eventually, they will push the window up less before kicking the breaker before going completely out. I've had to change both window motors in my 1996 Camaro (the driver side twice) because the motor went out...I had these same symptoms.
Oh, by the way, the motor is a pain to change.
RichieB16 is offline   Reply With Quote Quick reply to this message
Old Sep 9th, 07, 11:33 AM   #3 (permalink)
The motor is bad, I've replaced my wife's motor 3 times, all with gm motors.
There is 1 bolt, or is it 2? that's hard to get to. I drilled a hole through the fiberglass on the other side of the bolt that holds the motor to the regulator. Now it's accessible for replacement from the door panel side of the door.
Dale
68 Dana 302, 68 rs 327 daily driver/family car, 71 rs, track car/ driver, 68 firebird 400, 70 formula 400, 73 type LT, 98 TA, 2 goofy kids and an incredible wife.
dale68z is offline   Reply With Quote Quick reply to this message
Old Sep 10th, 07, 07:29 AM   #4 (permalink)
I never did take those amperage measurements but was able to confirm that when the driver's motor stalls, the passenger side works fine. Yesterday it stalled and then when it finally started working again and ran faster than it has in a couple of years...weird.
I had an old pherd once that had a motor problem. The pinion had a rubber coupler, I presume to reduce motor noise. The rubber in the coupler came apart and gummed up the works. I don't suppose I'll get that lucky with this one though.
My new Heilm manual should arrive this week. Looks like I've got a project. I've replaced a few motors in the past. Most required drilling through the regulator gear and bolting it in place to prevent it snapping back when the motor was removed. I presume this one is similar, but it seems everyone agrees - this one is a pain. Wish me luck and thanks for your help. I'll let you know how it goes in a week or so.
Old Sep 10th, 07, 08:00 AM   #5 (permalink)
DjD
DjD's Avatar
Very common issue... The first link is a motor fix, the second is a how to replace the motor. I found the least expensive (ebay $20-$30) window motor I could when I did the '96. It was still working well when I sold the car.
http://web.camaross.com/forums/archi.../t-145075.html
http://shbox.com/page/windowmotor.html
...Dennis
DjD is offline   Reply With Quote Quick reply to this message
Old Sep 10th, 07, 05:04 PM   #6 (permalink)
Z28 Mark's Avatar
Post Re: 2002 DS Electric Window Problem
I just did my 2001 passenger side window motor about a month ago and I used the shoe box link that DjD posted. It only took about 2 1/2 hours to do. I have done both drivers and passenger side windows and the first window takes the longest as you are just not sure about anything. Try and print it out in color and read it at least twice and then read it again. You are correct about drilling out the rivets and then bolting the new motor in place. I too picked the motors up from a place on e-bay called A1Auto.com ( they are out of New York). Good Luck!
Mark (AKA Z28 Mark)
1973 Z28 2001 Z28
Camaros Limited~Nor Cal
Z28 Mark is offline   Reply With Quote Quick reply to this message
Old Oct 27th, 07, 08:47 PM   #7 (permalink)
Well I just finished the window motor repair today. I was able to refurbish the original and plan to take the $245 regulator assembly back to GM.
The motor had water in it for one thing. Nothing was severly damaged as a result, but no bueno none the less.
The armature looked like it had a film of dried, burned, grease on it. I buffed up the armature, dried it out, and then focused on that thermal breaker I've heard about.
The thermal breaker was adding about another 0.7 Ohms of resistance and would drop a substantial amount of voltage with a 3A test load. I tried to peen the breaker with a center punch, but that made no difference. I got it good and hot with a soldering iron and soldered it together with a fluxy piece of solder.
Getting the brushes back in wasn't easy. Definately some tounge holding involved and it took a couple tries until I jigged a little strap to hold one of the brushes in place until I was about to assemble it.
It took me considerable more than 2 hrs, though I wasn't in a big hurry. The rivets GM provides are 1/4" and you'll have a hard time finding a rivet gun to pop them. I used some 1/4" button-head cap screews and 4 out-of-round lock nuts. I tac welded the nuts in place and put it back together. I imagine I spent 4 hours on it.
If GM will buy back the new regulator the repair will have cost me about $0.75 in grease, cleaner, compressed, and a band-aid. Now lets see if she'll hold for another 20,000 miles.
Location
Location
First Name
» Recent Discussions
frustration with...
Yesterday 04:55 PM
Last post by X-77 keith
Today 03:23 AM
5 Replies, 119 Views
Steering Arm Problem 68...
Yesterday 02:18 PM
Last post by 130fe
Today 02:02 AM
1 Replies, 73 Views
69 Camaro with Dart 406"...
Yesterday 10:41 AM
Last post by friendlyviper
Yesterday 08:38 PM
6 Replies, 134 Views
What do these two black...
Sep 10th, 19 01:32 PM
Last post by 67sc
Yesterday 08:18 PM
12 Replies, 378 Views
Passenger door side view...
Sep 8th, 19 10:38 AM
Last post by 69Z28
Yesterday 07:10 PM
22 Replies, 534 Views
67 camaro smog pump...
Yesterday 06:08 PM
by Niblet
Last post by Niblet
Yesterday 06:08 PM
0 Replies, 58 Views
Wiring HEI distributor...
Jul 7th, 19 12:05 AM
Last post by graeme
Yesterday 05:59 PM
14 Replies, 582 Views
Adding...
Yesterday 05:57 AM
Last post by SOA-Nova
Yesterday 05:52 PM
3 Replies, 121 Views
Buying a 68-69 Camaro 350
Sep 8th, 19 10:41 PM
Last post by kookykrispy
Yesterday 05:37 PM
13 Replies, 437 Views
Door Glass Doesn't Match...
Sep 14th, 19 05:48 AM
Yesterday 05:17 PM
5 Replies, 171 Views
