1996 Bose system high-pitch hiss. Help? - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Sep 9th, 07, 07:09 PM   #1 (permalink)
Hi all,
My 96 has the BOSE sound and it always had a high-pitch hiss that wouldn't go away, even when the system was turned off. When the factory CD-player died, I replaced it with an aftermarket head. The hiss is still there. Anybody else had this problem and know where to start looking? I'm not running any amplifier, just plugged in the new head unit and it sounds fine, except when it's OFF. It doesn't matter whether it's set on CD, radio, or AUX.
AS soon as I open the doors, the hiss stops.
PeteHoyt is offline   Reply With Quote Quick reply to this message
Old Sep 11th, 07, 05:27 AM   #2 (permalink)
Re: 1996 Bose system high-pitch hiss. Help?
Is it a hiss or a whine? Ide start by checking all my grounds...MAKE SURE they're tight to a piece of metal with the paint scraped off.
94TwitchZ28 is offline   Reply With Quote Quick reply to this message
Old Sep 11th, 07, 12:53 PM   #3 (permalink)
Without knowing precisly what you're hearing it's hard to say. It's difficult to keep audible noises out of power and ground feeds. One of the most typical ways noise gets into a system is through the ground. For example, if your stereo's ground is shared with a noisey counterpart (like the ECM for example), the counterparts noise components will ride on the ground and couple into the radio.
I'm not sure what I can offer you since I don't know exactly what you're hearing. You might try some fuse pulling to see if shutting down the ECM for example makes the noise go away. You might be able to install a noise filter on the power or run an alternate ground to decouple the noise.
dnult is offline   Reply With Quote Quick reply to this message
Old Sep 11th, 07, 01:03 PM   #4 (permalink)
wiskeesour's Avatar
Maybe install an RF filter from Rad!O shack in the ground wire for the head unit. That may fix it. I would look at all the grounds also...
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
» Recent Discussions
15 inch rally wheel trim...
Sep 8th, 19 12:35 PM
Last post by BOOGIES
Today 08:40 AM
11 Replies, 271 Views
Replacing pinion seal &...
Jul 17th, 05 07:12 AM
Last post by Niblet
Today 08:24 AM
12 Replies, 16,235 Views
bucket seat lock latch...
Today 07:26 AM
Last post by aircavalryveteran
Today 07:26 AM
0 Replies, 21 Views
carb tuning with...
Sep 16th, 19 08:47 AM
Last post by bhodgdon400
Today 06:46 AM
21 Replies, 329 Views
Shock from horn
Aug 22nd, 19 06:59 AM
Last post by bondora68
Today 06:39 AM
18 Replies, 558 Views
Door Glass Doesn't Match...
Sep 14th, 19 05:48 AM
Last post by The Camaro Guy
Today 05:44 AM
12 Replies, 336 Views
Hello from Chicago
Yesterday 08:14 AM
Last post by Andrew69
Today 05:32 AM
3 Replies, 75 Views
Fuel line routing issue...
Sep 9th, 19 05:36 AM
by HawkX66
Last post by HawkX66
Today 04:37 AM
15 Replies, 376 Views
Took home my 2nd Best in...
Sep 16th, 19 06:37 AM
Last post by pittpens24
Today 04:18 AM
12 Replies, 239 Views
Humpday Humor, 9/17 ......
Yesterday 03:14 PM
Last post by flat tire
Today 04:10 AM
5 Replies, 148 Views
