95 v6 Fuel gauge off track! - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Oct 22nd, 07, 08:50 PM   #1 (permalink)
Unhappy 95 v6 Fuel gauge off track!
Ok My fuel level is way off track. It's reading it wrong. When I fill up It goes over the the F Line. I usualy get 350 miles to a tank I fill up every 300 miles. 15.5 gallon tank. When I hit around 200 miles it goes down to about half tank.. Oh jezze I took off the whole dash out I played around with the orange stick that reads it. I started the engine and I was pushing it back and forth it keep going moving pass the F mark. I also took the fuse out for the gauge lights nope still reading it wrong.. I went under the car to see if there is a squeze in the fuel line nope it's all good. I went to the back of the car and went under the rear. I took off the gas cap and took the cover off I can fit my hand in. There was a black thing that had like 4 tubes going into it. I dont know how to fix the problem. Can it be the Fuel sending unit? Please help I love working on my car I do my own repairs as well. So I kinda need help so anyone?
giants4life07 is offline   Reply With Quote Quick reply to this message
Old Oct 25th, 07, 03:04 AM   #2 (permalink)
Re: 95 v6 Fuel gauge off track!
I have a 95 Convertible with 3.4 and 5 speed that has the exact same problem. I replaced the fuel sending unit and the gas gauge as well. Total waste of money as it is still doing the exact same thing. I do all the work on my car as well and if there is someting i've missed or a solution to this problem I would like to know what it is as well. Thanks
rdmoore62 is offline   Reply With Quote Quick reply to this message
Old Oct 25th, 07, 08:54 AM   #3 (permalink)
thanks buddy i kinda figure is it was that oh jeeze..
GREAT....
Old Oct 25th, 07, 05:33 PM   #4 (permalink)
the fuel guage reads a potentiometer in the sending unit to tell the guage the fuel level...if the signal is broken between the guage and the float, the needle will pin over full...if the rheostat in the float (potentiometer) has an open, or broken wire, the guage will read full...if the sending unit has a bad ground, you guessed it, over full...i`d locate the signal wire at the sending unit, and ground it out, to see if the guage is working...if you ground it, and the guage moves, then diagnose the sending unit...hope this helps...
kustomwerker is offline   Reply With Quote Quick reply to this message
Old Nov 13th, 07, 05:39 AM   #5 (permalink)
I have a 95 Camaro RS with a V6 and i have the same problem. Its never right. when i stop and go the gauge goes crazy.
95CamaroRS is offline   Reply With Quote Quick reply to this message
Old Nov 28th, 07, 06:03 AM   #6 (permalink)
The gas tank on fourth gens is kinda shaped like a V. The gauge will stay at full for a long time then start to drop rapidly as the tank empties. The gauge is only good for empty or full readings. They all act this way. If your gauge seems to be moving around rapidly while driving, sort of like a needle dance, the gauge is going bad.
Bronze is offline   Reply With Quote Quick reply to this message
Old Jul 1st, 08, 12:16 PM   #7 (permalink)
Big Thunder's Avatar
i have a 94 with the 3.4 and the samething but it is accurate
Big Thunder is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
» Recent Discussions
Rear Rub when turning
Today 08:55 AM
Last post by JakeSpoon
Today 08:55 AM
0 Replies, 6 Views
carb tuning with...
Sep 16th, 19 08:47 AM
Last post by HawkX66
Today 08:54 AM
22 Replies, 334 Views
15 inch rally wheel trim...
Sep 8th, 19 12:35 PM
Last post by BOOGIES
Today 08:40 AM
11 Replies, 274 Views
Replacing pinion seal &...
Jul 17th, 05 07:12 AM
Last post by Niblet
Today 08:24 AM
12 Replies, 16,239 Views
bucket seat lock latch...
Today 07:26 AM
Last post by aircavalryveteran
Today 07:26 AM
0 Replies, 21 Views
Shock from horn
Aug 22nd, 19 06:59 AM
Last post by bondora68
Today 06:39 AM
18 Replies, 559 Views
Door Glass Doesn't Match...
Sep 14th, 19 05:48 AM
Last post by The Camaro Guy
Today 05:44 AM
12 Replies, 337 Views
Hello from Chicago
Yesterday 08:14 AM
Last post by Andrew69
Today 05:32 AM
3 Replies, 76 Views
Fuel line routing issue...
Sep 9th, 19 05:36 AM
by HawkX66
Today 04:37 AM
15 Replies, 376 Views
Took home my 2nd Best in...
Sep 16th, 19 06:37 AM
Last post by pittpens24
Today 04:18 AM
12 Replies, 240 Views
