turbo help?!?!?! - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Oct 29th, 07, 02:05 PM   #1 (permalink)
turbo help?!?!?!
i have a 94 lt1 z28 and i decided to go with the sts trubo kit. it says you can run 7 psi stock and not hurt your motor, well i want to run 12psi and was wondering what i need to do to the internals of the motor?
Anything help!
thanx
gokillaj is offline   Reply With Quote Quick reply to this message
Old Oct 29th, 07, 04:21 PM   #2 (permalink)
Re: turbo help?!?!?!
Seven psi of boost on a regular compression engine is about the limit before detonation. You must also retard timing, I think 1* for every lb of boost.
Any more boost pressure and building the short block to have 8:1 static compression ratio is the norm. Also, having a boost-referenced fuel pressure regulator is essential also. More boost, more fuel. Having the air intercooled helps in reducing combustion temperature to thwart detonation.
Just my thoughts. Maybe other experts here will divulge their knowledge.
Old Oct 29th, 07, 05:43 PM   #3 (permalink)
intercooling is a must for turbos, as they use hot exh gasses to build boost...hot air charge makes detonation easier, and a very big nono...a boost timing master would be a good addition, as it will pull timing thru a boost referenced port...carb or fi???as everett said, 8 or 8.5 to 1 is a good place to be for a boosted motor, and you may be able to achieve that with a blower grind cam, as the lsa will help to bleed off compression...the guy to talk to would prolly br camcojb...he`s a moderator, and has a lot of force fed experience...most of my experience is with 1 procharged 383...but most all the same principals apply...
kustomwerker is offline   Reply With Quote Quick reply to this message
Old Oct 29th, 07, 08:49 PM   #4 (permalink)
I have 10.5 to 1 comp. how can i lower it? what internals do i have to change to make it for 12 psi?
Old Oct 30th, 07, 04:29 AM   #5 (permalink)
10.5 is too much for 12 lbs imo...post in the performance section with a cam reccomendation to lower your dcr to a more usable (like 8`s ) comp ratio...i`m sure jody or tim or pdq can give you some suggestions...not even sure you can bleed off that much comp...
Location
Location
First Name
» Recent Discussions
frustration with...
Yesterday 04:55 PM
Last post by X-77 keith
Today 03:23 AM
5 Replies, 115 Views
Steering Arm Problem 68...
Yesterday 02:18 PM
Last post by 130fe
Today 02:02 AM
1 Replies, 72 Views
69 Camaro with Dart 406"...
Yesterday 10:41 AM
Last post by friendlyviper
Yesterday 08:38 PM
6 Replies, 132 Views
What do these two black...
Sep 10th, 19 01:32 PM
Last post by 67sc
Yesterday 08:18 PM
12 Replies, 376 Views
Passenger door side view...
Sep 8th, 19 10:38 AM
Last post by 69Z28
Yesterday 07:10 PM
22 Replies, 531 Views
67 camaro smog pump...
Yesterday 06:08 PM
by Niblet
Last post by Niblet
Yesterday 06:08 PM
0 Replies, 58 Views
Wiring HEI distributor...
Jul 7th, 19 12:05 AM
Last post by graeme
Yesterday 05:59 PM
14 Replies, 581 Views
Adding...
Yesterday 05:57 AM
Last post by SOA-Nova
Yesterday 05:52 PM
3 Replies, 118 Views
Buying a 68-69 Camaro 350
Sep 8th, 19 10:41 PM
Last post by kookykrispy
Yesterday 05:37 PM
13 Replies, 436 Views
Door Glass Doesn't Match...
Sep 14th, 19 05:48 AM
Yesterday 05:17 PM
5 Replies, 169 Views
