98 Camaro 3.8L hard start cold. - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Nov 21st, 07, 03:57 PM   #1 (permalink)
I just picked up another camaro, for a driver, for the wife. I have a cold starting problem. When the car is cold it cranks a long time and when it starts it runs rough for a bit and then clears up. If I hold the throttle open a little bit is starts quicker but it still misses intill it clears out. The car has 65,000 miles on it. The plugs are AC double platinum plugs. I dont know how long they have been in but from what I recall they should be good for 100,000miles. I could only get to one plug easily and I dont want to pull them out if not needed. anyone know of an TSB-s or had similar problems?
Milan
67 Blown Alcohol Camaro "The Combat Rat" 8-71 and E-85/71 BB SS Chevelle "cheap street" (clone) 12.871 @ 107.59 w/1.915 60' and spinning /2002 35th anniv SS Z28 conv./74 454 El Camino .
Milan is offline   Reply With Quote Quick reply to this message
Old Nov 23rd, 07, 06:13 PM   #2 (permalink)
Re: 98 Camaro 3.8L hard start cold.
Most likely has a bad fuel pump. Check the fuel pressure, if it looses pressure with engine off, I would highly suspect a leaking check valve in the fuel pump.
pressure can bleed down slowly, but shouldn't drop to 0. Idealy it will hold pressure forever.
Those pumps suck to install.
68 Dana 302, 68 rs 327 daily driver/family car, 71 rs, track car/ driver, 68 firebird 400, 70 formula 400, 73 type LT, 98 TA, 2 goofy kids and an incredible wife.
dale68z is offline   Reply With Quote Quick reply to this message
Old Nov 24th, 07, 04:37 AM   #3 (permalink)
I thought it would be a bad fuel pump at first also. How would that explain the missfire or rough running?
Old Nov 24th, 07, 04:40 AM   #4 (permalink)
I would suspect lack of ECM f/pump relay control or burnt contacts of the relay.
Turning on the ign switch and you should hear the f/pump hum for a 2-3 seconds. I would wager the f/pump is getting power through the secondary route - oil pressure switch.
Another problem area, confirm fuel pressure first, could be the two wire coolant temp sensor. If the sensor is not 'cold' enough, fuel system will distribute a lean fuel mixture and make the engine crank longer for the engine to 'collect' enough fuel, then the engine starts up.
Old Nov 24th, 07, 07:33 AM   #5 (permalink)
Well The pressure goes right up to 45-50 PSI. I will need to let it cool down again and get a reading on the temp sensor. I had to pull it in because I need to replace the alternator and tensioner (The somebody that designed that thing needs to be slapped!) I will install new plugs while its inside.
Old Nov 24th, 07, 01:20 PM   #6 (permalink)
The pump whines as soon as the key is turned on. and the coolant sensor is a 3 wire sensor. I unplugged the sensor to inspect for corrosion and nothing... I will let is sit outside and then get a coolant temp reading later this evening.
Milan
Old Nov 25th, 07, 12:54 PM   #7 (permalink)
Well the coolant temp sensor read 41*. Thats not the problem. Any other suggestions?
Old Nov 25th, 07, 02:23 PM   #8 (permalink)
I'd probably replace the platinum spark plugs with the stock type.
Old Nov 25th, 07, 06:23 PM   #9 (permalink)
I already replaced the plugs and wires (cut the heck out of my hands). It came with double platinum plugs from the factory, so that is what I put back in. I was thinking about possible dirty fuel injectors. It seems to be a cold start problem after it sits for over an hour. I have to open the throttle a little bit and that seems to help. It feels like it is loading up at least one cylinder, as I have to hold the RPMs up untill the plug clears up. I wonder if a faulty coil pack could cause this type of problem?
Old Nov 26th, 07, 03:49 AM   #10 (permalink)
It could be a faulty coil pack.
Old Nov 27th, 07, 03:28 PM   #11 (permalink)
Well I plugged a spark tester to the 3/6 coil pack first thing this morning and its sparking away. I was sure that was the problem..
Old Nov 27th, 07, 04:17 PM   #12 (permalink)
Cool !! So, its back on the road?
Old Nov 27th, 07, 04:53 PM   #13 (permalink)
The cold start missfire is not fixed. There was nothing wrong that I could see with the coil output. The injector is the only thing left. I have never seen one that malfunctions dependant on cold temerature. when they get hot I have seen them fail, but not on a cold start. I am stumped.
Old Nov 27th, 07, 05:59 PM   #14 (permalink)
Maybe a can of fuel injector cleaner with the next tankful of fuel?
Old Nov 28th, 07, 03:28 AM   #15 (permalink)
I will try swapping the coil pack and injector to another cylinder and see if the computer tracks the miss to another cylinder, is what I am thinking. I have tried the injector cleaner last week...
Location
Location
First Name
» Recent Discussions
Alternator Wisdom?
Today 01:49 PM
Last post by really_n0b0dy
Today 01:49 PM
0 Replies, 13 Views
Original 67 SS350 engine...
Sep 12th, 19 04:30 PM
by stryqer
Last post by Niblet
Today 01:31 PM
7 Replies, 330 Views
1991 camaro horn switch
Sep 14th, 19 04:27 PM
Last post by BRICO69
Today 01:23 PM
2 Replies, 98 Views
bucket seat lock latch...
Today 07:26 AM
Last post by allanjs
Today 12:56 PM
1 Replies, 45 Views
Replacing pinion seal &...
Jul 17th, 05 07:12 AM
Last post by big gear head
Today 12:49 PM
17 Replies, 16,309 Views
carb tuning with...
Sep 16th, 19 08:47 AM
Last post by HawkX66
Today 12:21 PM
25 Replies, 383 Views
How to upload pic of my...
Today 10:56 AM
Last post by dhutton
Today 12:03 PM
2 Replies, 49 Views
Rear Rub when turning
Today 08:55 AM
Last post by DjD
Today 09:24 AM
1 Replies, 66 Views
Overheating Concerns '67...
Sep 5th, 19 12:34 PM
Last post by 69-er
Today 09:06 AM
35 Replies, 832 Views
15 inch rally wheel trim...
Sep 8th, 19 12:35 PM
Last post by BOOGIES
Today 08:40 AM
11 Replies, 285 Views
