Miss Shift Damage? - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Nov 24th, 07, 05:37 AM   #1 (permalink)
Question Miss Shift Damage?
ok i jsut got off work, very tired. i get on the onramp and decide to mash the pedal. shift nicly into second. and the top of second i go to throw it into third and if im not mistaked i think i accidental threw it into first. when i released the clutch the back end starting flipping out. so i jammed the clutch back in and corrected my problem. i guestimate i was going about 90 mph when i thre it into first. it seemed to drive fine the rest of the way home. think there could be any damage and if so what?
Sloppsta is offline   Reply With Quote Quick reply to this message
Old Nov 26th, 07, 05:19 PM   #2 (permalink)
Re: Miss Shift Damage?
In all likelyhood it will be fine but just to be sure it would be a good idea to take a look at all the attaching points to the chassis.
Milan
67 Blown Alcohol Camaro "The Combat Rat" 8-71 and E-85/71 BB SS Chevelle "cheap street" (clone) 12.871 @ 107.59 w/1.915 60' and spinning /2002 35th anniv SS Z28 conv./74 454 El Camino .
Milan is offline   Reply With Quote Quick reply to this message
Old Nov 26th, 07, 10:16 PM   #3 (permalink)
Engine damage would be my biggest concern. Your rev limiter will not keep the engine from winding out beyond the limit when a force is applied from the drivetrain. If it runs fine you got probably got lucky.
Vegas69 is offline   Reply With Quote Quick reply to this message
Old Nov 26th, 07, 10:32 PM   #4 (permalink)
First of all I'd be worried about bent valves and even PtV contact.
If it's no missing or rattling unnecessarily, go buy a lottery ticket!
Black C5 Z06 is offline   Reply With Quote Quick reply to this message
Old Dec 3rd, 07, 06:40 PM   #5 (permalink)
I'd check to see that the pushrods are all still straight. It's a weak link in the valvetrain.
67 Camaro: 454/TH400/4.10 12 bolt. Lots of options: PS/PDB/PW, tilt, tach, gauges and more. K-K + 797-Z...
"Politics is the art of looking for trouble, finding it whether it exists or not, diagnosing it incorrectly and applying the wrong remedy" - Sir Ernest Benn
PowerWindows is offline   Reply With Quote Quick reply to this message
Old Dec 4th, 07, 10:05 AM   #6 (permalink)
Yep, more thank likely you are just fine.
But in an LS1 you will bend the pushrods before anything else when you miss a shift like that.
98 Trans Am - LS1, T56 swap in the works
79 Bandit Trans Am - 408 Pontiac/4-spd - SOLD
68 Camaro (Patriot Dream car) - Built 327, Super T-10 4-spd, lowered and nitroused PT machine
4birdman is offline   Reply With Quote Quick reply to this message
Old Dec 4th, 07, 03:27 PM   #7 (permalink)
chances are the tires broke free before anything else...i`d say you`re prolly fine...but look at the trans and engine mounts...
kustomwerker is offline   Reply With Quote Quick reply to this message
Old Dec 5th, 07, 09:13 PM   #8 (permalink)
Even though the tires broke loose, It's still very simple to mechanically over rev the engine.
If your car doesn't sound like a sound like a sewing machine right now, count yourself lucky. This is one of the most common sources of valvetrain damage.
Rhino is offline   Reply With Quote Quick reply to this message
Old Dec 6th, 07, 04:31 AM   #9 (permalink)
it is absolutely possible to over-rev the engine mechanically...i`m not saying it isnt...i`m saying that at his quoted 90 mph, it would`ve been difficult at least to get it into 1st...dropping the clutch with such a drastic difference between allowable speed and actual speed would`ve fragged the tires instantly...it isnt like going from 5th to 3rd, where you have a huge mechanical advantage from trans to motor...from 3 to 1, the mechanical advantage is hugely reduced...as 1st is the best mechanical advantage from motor to trans, its worst in reverse...am i making sense???this is why it`s easier to pop start a car in a higher gear than a lower gear...in such a case, the m/a would be better in 5th than 1st...
Old Dec 6th, 07, 07:53 AM   #10 (permalink)
Oh yea, It makes absolute sense. I just wanted to make sure that everyone understands that just because the tires break loose, it's still possible to over rev. I've seen that misconception on other boards and didn't want to get it started here.
Old Dec 7th, 07, 04:22 AM   #11 (permalink)
right on ryan...
Location
Location
First Name
» Recent Discussions
Rear Rub when turning
Today 08:55 AM
Last post by JakeSpoon
Today 08:55 AM
0 Replies, 9 Views
carb tuning with...
Sep 16th, 19 08:47 AM
Last post by HawkX66
Today 08:54 AM
22 Replies, 334 Views
15 inch rally wheel trim...
Sep 8th, 19 12:35 PM
Last post by BOOGIES
Today 08:40 AM
11 Replies, 274 Views
Replacing pinion seal &...
Jul 17th, 05 07:12 AM
Last post by Niblet
Today 08:24 AM
12 Replies, 16,239 Views
bucket seat lock latch...
Today 07:26 AM
Last post by aircavalryveteran
Today 07:26 AM
0 Replies, 21 Views
Shock from horn
Aug 22nd, 19 06:59 AM
Last post by bondora68
Today 06:39 AM
18 Replies, 559 Views
Door Glass Doesn't Match...
Sep 14th, 19 05:48 AM
Last post by The Camaro Guy
Today 05:44 AM
12 Replies, 337 Views
Hello from Chicago
Yesterday 08:14 AM
Last post by Andrew69
Today 05:32 AM
3 Replies, 77 Views
Fuel line routing issue...
Sep 9th, 19 05:36 AM
by HawkX66
Today 04:37 AM
15 Replies, 376 Views
Took home my 2nd Best in...
Sep 16th, 19 06:37 AM
Last post by pittpens24
Today 04:18 AM
12 Replies, 240 Views
