fuel pressure regulator - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Nov 24th, 07, 08:33 PM   #1 (permalink)
I want to lean my 94 Z out and Im looking into getting an adjustable fuel pressure regulator. What would be the best and is there a way to just modify the stock one for the same result for less money. Thanx
94TwitchZ28 is offline   Reply With Quote Quick reply to this message
Old Nov 24th, 07, 09:37 PM   #2 (permalink)
Re: fuel pressure regulator
I'll awnser your question first......yes, there is an adjustable fuel pressure regulator available for the LT1 engine. If you want the best, look HERE. You will need part number 13107.
I am concerned as to why you want to lean it out. Short of a possiblity of better MPG's or a dirty air filter, why would you want to do such a thing?
If you are to use a FPR to lean it out, it will not do anything but have a very bad effect in how the engine performs.
Ok, lets say you take the pressure down to 30PSI from the factory 46PSI. When you drive it and put a load on the engine, the computer will try keep the fuel/air mixture to 14.7 to 1. If there is not enough fuel pressure there to make this happen, your runability will be horrible because the computer is trying to keep the injectors open for alot longer, therfore you have a bad spray pattern and poor all around performance.
The best way to properly lean it out is to do a computer tune.
Hope this helps,
Joe
1969 Camaro....LS1/T-56.............
In the early stages of Pro-Touring
Kokamo is offline   Reply With Quote Quick reply to this message
Old Nov 25th, 07, 06:17 AM   #3 (permalink)
ok ok...after i had posted the original post...i found an article all about how AFPRs on these motors are pretty much useless...so, now, Ide have to go to a shop the have the brain reprogrammed right? any idea on how much it would cost? Tis the season for empty wallets
Old Nov 25th, 07, 08:33 AM   #4 (permalink)
Yes, it tis the season for emty wallets.
As far as reprogramming, there are lots of people out there that do mail order tunes. You simply mail them your computer, they retune it to your specifications, and then they send it back to you. That will be where you need to do a little searching. I have had all my tuning done by a guy in Canton, Ohio. His name is Jamie Lippencott and owns LSRacingchips.com. Now, his site is not up anylonger because he simply got too overwhelmed by mailorder tunes and is also too busy with his in house dyno tunes, so he is no longer taking in mail order tunes. I am currently thinking of performing my own tunes.....thats going to take some research, but I know it can be done.
Go over to LS1LT1.com and do a search of how to DIY tune or simply find someone that will do it for you.
Joe
Location
Location
First Name
» Recent Discussions
Alternator Wisdom?
Today 01:49 PM
Last post by really_n0b0dy
Today 01:49 PM
0 Replies, 13 Views
Original 67 SS350 engine...
Sep 12th, 19 04:30 PM
by stryqer
Last post by Niblet
Today 01:31 PM
7 Replies, 330 Views
1991 camaro horn switch
Sep 14th, 19 04:27 PM
Last post by BRICO69
Today 01:23 PM
2 Replies, 98 Views
bucket seat lock latch...
Today 07:26 AM
Last post by allanjs
Today 12:56 PM
1 Replies, 45 Views
Replacing pinion seal &...
Jul 17th, 05 07:12 AM
Last post by big gear head
Today 12:49 PM
17 Replies, 16,309 Views
carb tuning with...
Sep 16th, 19 08:47 AM
Last post by HawkX66
Today 12:21 PM
25 Replies, 383 Views
How to upload pic of my...
Today 10:56 AM
Last post by dhutton
Today 12:03 PM
2 Replies, 49 Views
Rear Rub when turning
Today 08:55 AM
Last post by DjD
Today 09:24 AM
1 Replies, 66 Views
Overheating Concerns '67...
Sep 5th, 19 12:34 PM
Last post by 69-er
Today 09:06 AM
35 Replies, 832 Views
15 inch rally wheel trim...
Sep 8th, 19 12:35 PM
Last post by BOOGIES
Today 08:40 AM
11 Replies, 287 Views
