Drivers Side Carpet Getting Wet - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Dec 14th, 07, 01:26 PM   #1 (permalink)
1998 Camaro: Here is the issue in a nutshell. When I run the heater I do not have an issue, but it appears that when I run the Defroster the floor gets wet on the drivers side. The system produces good heat and the blower works fine, however the condensation from the unit appears (at least partially) to not drain overboard. It may be getting wet on the passenger side also but not visibly looking at the carpet. The drivers side is very apparent when the floormat is removed. I get 2 distinct wet areas, 1 in the depression near the pedals and 1 near the seat close to the hump for the transmission/console area. I have removed the lower panels underneath the dash and attempted to find the leak/blockage to no avail. Any help would be appreciated.
Hawkdriver is offline   Reply With Quote Quick reply to this message
Old Dec 14th, 07, 04:31 PM   #2 (permalink)
Re: Drivers Side Carpet Getting Wet
the drain for the a/c or heater box is outside under car. when defroster is on a/c compressor cycles. makes the moisture. the drain is usually on passenger side of car right below inner fender in between the exhaust and fender. most likely a black plastic tube. may see it from top of car. most can be seen real good under car.
hereitis67 is offline   Reply With Quote Quick reply to this message
Old Jan 10th, 08, 05:16 PM   #3 (permalink)
had the same proble with ac. cleared the drain no problems sence
bowtiemonster is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
» Recent Discussions
15 inch rally wheel trim...
Sep 8th, 19 12:35 PM
Last post by BOOGIES
Today 08:40 AM
11 Replies, 271 Views
Replacing pinion seal &...
Jul 17th, 05 07:12 AM
Last post by Niblet
Today 08:24 AM
12 Replies, 16,235 Views
bucket seat lock latch...
Today 07:26 AM
Last post by aircavalryveteran
Today 07:26 AM
0 Replies, 21 Views
carb tuning with...
Sep 16th, 19 08:47 AM
Last post by bhodgdon400
Today 06:46 AM
21 Replies, 330 Views
Shock from horn
Aug 22nd, 19 06:59 AM
Last post by bondora68
Today 06:39 AM
18 Replies, 558 Views
Door Glass Doesn't Match...
Sep 14th, 19 05:48 AM
Last post by The Camaro Guy
Today 05:44 AM
12 Replies, 336 Views
Hello from Chicago
Yesterday 08:14 AM
Last post by Andrew69
Today 05:32 AM
3 Replies, 75 Views
Fuel line routing issue...
Sep 9th, 19 05:36 AM
by HawkX66
Last post by HawkX66
Today 04:37 AM
15 Replies, 376 Views
Took home my 2nd Best in...
Sep 16th, 19 06:37 AM
Last post by pittpens24
Today 04:18 AM
12 Replies, 239 Views
Humpday Humor, 9/17 ......
Yesterday 03:14 PM
Last post by flat tire
Today 04:10 AM
5 Replies, 148 Views
