engine power loss - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Dec 20th, 07, 10:24 AM   #1 (permalink)
engine power loss
I have a 2000 camaro V6 . I have a error message"reduced engine power" when the light comes on the car loses power and will only perform at idle speed.
I diagnosed the codes of P1221,P1516. Which has something to do with the throttle position. Any suggestions? I'm wondering if it is the throttle sensor on throttle body or the sensor on the gas pedal.
bear61255 is offline   Reply With Quote Quick reply to this message
Old Dec 20th, 07, 03:59 PM   #2 (permalink)
Re: engine power loss
I would replace the tps.
CamaroBrandon is offline   Reply With Quote Quick reply to this message
Old Dec 21st, 07, 05:29 AM   #3 (permalink)
Didn't know there was a sensor on the pedal. My guess would be the TPS on the throttle body. You should be able to disconnect it and measure resistance between the center and an outer terminal. Then move the throttle smoothly through it's range of motion looking for a smooth change in resistance. The high-use spots are where the problems show up. Usually that is just above idle.
dnult is offline   Reply With Quote Quick reply to this message
Old Dec 21st, 07, 08:45 AM   #4 (permalink)
Thanks guys, will give that a try...
Old Dec 21st, 07, 08:51 AM   #5 (permalink)
Does the 2000 v6 have a drive by wire throttle?
If it does, that's the problem.
JimM is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
» Recent Discussions
Alternator Wisdom?
Today 01:49 PM
Last post by really_n0b0dy
Today 01:49 PM
0 Replies, 13 Views
Original 67 SS350 engine...
Sep 12th, 19 04:30 PM
by stryqer
Last post by Niblet
Today 01:31 PM
7 Replies, 332 Views
1991 camaro horn switch
Sep 14th, 19 04:27 PM
Last post by BRICO69
Today 01:23 PM
2 Replies, 99 Views
bucket seat lock latch...
Today 07:26 AM
Last post by allanjs
Today 12:56 PM
1 Replies, 45 Views
Replacing pinion seal &...
Jul 17th, 05 07:12 AM
Last post by big gear head
Today 12:49 PM
17 Replies, 16,311 Views
carb tuning with...
Sep 16th, 19 08:47 AM
Last post by HawkX66
Today 12:21 PM
25 Replies, 384 Views
How to upload pic of my...
Today 10:56 AM
Last post by dhutton
Today 12:03 PM
2 Replies, 50 Views
Rear Rub when turning
Today 08:55 AM
Last post by DjD
Today 09:24 AM
1 Replies, 67 Views
Overheating Concerns '67...
Sep 5th, 19 12:34 PM
Last post by 69-er
Today 09:06 AM
35 Replies, 834 Views
15 inch rally wheel trim...
Sep 8th, 19 12:35 PM
Last post by BOOGIES
Today 08:40 AM
11 Replies, 288 Views
