96 Camaro ventilation problem - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Jan 7th, 08, 07:45 AM   #1 (permalink)
Send a message via MSN to csn69ss Send a message via Yahoo to csn69ss
Hi There
I recently bought a 96 Camaro as a daily driver.
When I bought it the aircondition and ventilation system was working fine, now after the car has been stored for a short while the ventilation system is stock in a position where it gives air to the windshield and to the feet - no matter the position of the dial. The dial still switches the aircon on and off as i should be depending on position.
Are the ventilation flaps vacuum controlled?
Has anybody experienced something similar?
A few pics of my 4th gen.
1969 L65/TH350
csn69ss is offline   Reply With Quote Quick reply to this message
Old Jan 7th, 08, 12:37 PM   #2 (permalink)
Re: 96 Camaro ventilation problem
Sounds like the vacuum line under the hood that leads inside is broken somewhere and the door is in its at rest position which is defrost.
tumper is offline   Reply With Quote Quick reply to this message
Old Jan 7th, 08, 06:18 PM   #3 (permalink)
Yes it is in defrost position.
I will look for the vacuum line, thanks.
1969 L65/TH350
Old Jan 8th, 08, 12:37 AM   #4 (permalink)
Cant find the vacuum line, do you know where it is located
1969 L65/TH350
Old Jan 8th, 08, 07:04 PM   #5 (permalink)
I found a broken vacuum line near the vacuum box. Where the line runs through the "radiator core support" it has been rubbing against the steel edge - an easy fix.
Some help found here:
http://shbox.com/1/4th_gen_tech2.html#HVAC_vacuum
EDIT:
As mentioned car has been sitting for about a month, and it seems like mice has gotton to it. Found one more vacuum line chewed up, the line passing through the firewall. No spare vacuum lines available here, so I will try to make a temporary repair.
1969 L65/TH350
Location
Location
First Name
» Recent Discussions
Took home my 2nd Best in...
Yesterday 06:37 AM
Last post by BlueRibbon
Today 09:38 AM
10 Replies, 186 Views
Camaro specialties
Dec 19th, 10 06:14 AM
by perky
Last post by adjudimo
Today 09:35 AM
43 Replies, 14,042 Views
Overheating Concerns '67...
Sep 5th, 19 12:34 PM
Last post by allanjs
Today 09:20 AM
33 Replies, 755 Views
Coil Bracket
Today 03:34 AM
Last post by Z282NV
Today 09:16 AM
4 Replies, 87 Views
true car weight
Today 06:56 AM
Today 09:15 AM
5 Replies, 77 Views
Mid-pipes
Today 04:26 AM
Last post by bruce69camaro
Today 08:52 AM
4 Replies, 79 Views
Hello from Chicago
Today 08:14 AM
Last post by thedocs2
Today 08:14 AM
0 Replies, 22 Views
carb tuning with...
Yesterday 08:47 AM
Last post by bhodgdon400
Today 06:35 AM
15 Replies, 210 Views
Single leaf springs to...
Sep 15th, 19 07:33 AM
Today 06:35 AM
9 Replies, 242 Views
Shock from horn
Aug 22nd, 19 06:59 AM
Last post by bondora68
Today 06:30 AM
16 Replies, 496 Views
