97 z-28 dash went dead - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Jan 28th, 08, 10:01 AM   #1 (permalink)
Hello, all
Dash went dead and car will not start.
vrod2k2 is offline   Reply With Quote Quick reply to this message
Old Jan 28th, 08, 04:38 PM   #2 (permalink)
Re: 97 z-28 dash went dead
Hmmm, thats not good.
dnult is offline   Reply With Quote Quick reply to this message
Old Jan 28th, 08, 07:22 PM   #3 (permalink)
Have you checked your fuses? If I recall correctly this same thing happened to me a few years ago. The gauge fuse also controls the BCM. Without the BCM having power you won't be able to start the car.
By saying "won't start" do you mean it won't fire or it won't turn over? I'm assuming you mean it won't turn over.
Rhino is offline   Reply With Quote Quick reply to this message
Old Jan 28th, 08, 07:25 PM   #4 (permalink)
This is true...
I do have lights and radio.
Not sure if it is some ignition module?
Just looking for some advice as to where to start.
Old Jan 28th, 08, 07:28 PM   #5 (permalink)
the dash is dead and it will not turn over. Yes i did check the fuses...
Old Jan 28th, 08, 08:37 PM   #6 (permalink)
This happened on our 97 SS. We started looking at the key, ignition switch, and interlock. Take a hard look at your battery cables and the connection on both ends, especially under the positive lug on the battery! It's seems to be a pretty common problem for these and it's a lot cheaper to find it first rather than last. Good luck!
69 Z11 03D Van Nuys
82 Z28 Gordon Johncock's Pace Car
97 30th Z28 6 speed vert 1 of 175
69 z11 is offline   Reply With Quote Quick reply to this message
Old Jan 29th, 08, 06:30 AM   #7 (permalink)
If you turn the key forward, you don't get any dash lights? If not, I would suggest starting to look into electrical issues related to your gauge circuit.
It very well could end up being the problem you're dealing with. Otherwise, fixing them anyway wouldn't be time waisted.
EDIT: You may already know this... but remember you have more than one fuse box. Their will be one under hood in addition to the box within the drivers side dash. With your Drivers side door open, look at the edge of the dash. There's a small removable panel hiding the box.
Old Jan 29th, 08, 01:20 PM   #8 (permalink)
There is also an ignition switch that is either under the dash or is built into the collum. See if a local shop can preform a diagnostic. I had that exact same problem.
LT1RUNNER is offline   Reply With Quote Quick reply to this message
Old Jan 30th, 08, 03:28 PM   #9 (permalink)
Solution --- it was the ignition switch bolted to the steering col.
Thanks for all the help.
Location
Location
First Name
» Recent Discussions
Took home my 2nd Best in...
Yesterday 06:37 AM
Last post by BlueRibbon
Today 09:38 AM
10 Replies, 184 Views
Camaro specialties
Dec 19th, 10 06:14 AM
by perky
Last post by adjudimo
Today 09:35 AM
43 Replies, 14,017 Views
Overheating Concerns '67...
Sep 5th, 19 12:34 PM
Last post by allanjs
Today 09:20 AM
33 Replies, 751 Views
Coil Bracket
Today 03:34 AM
Last post by Z282NV
Today 09:16 AM
4 Replies, 81 Views
true car weight
Today 06:56 AM
Today 09:15 AM
5 Replies, 68 Views
Mid-pipes
Today 04:26 AM
Last post by bruce69camaro
Today 08:52 AM
4 Replies, 76 Views
Hello from Chicago
Today 08:14 AM
Last post by thedocs2
Today 08:14 AM
0 Replies, 19 Views
carb tuning with...
Yesterday 08:47 AM
Last post by bhodgdon400
Today 06:35 AM
15 Replies, 209 Views
Single leaf springs to...
Sep 15th, 19 07:33 AM
Today 06:35 AM
9 Replies, 242 Views
Shock from horn
Aug 22nd, 19 06:59 AM
Last post by bondora68
Today 06:30 AM
16 Replies, 493 Views
