Can headlights for 98 Camaro be - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Feb 18th, 08, 05:11 PM   #1 (permalink)
cleaned on the inside? I notice that there are two clips on the top of the head lights. Can the front part of the headlight be separated so that it can be cleaned and re-assembled. I have yet to find a pair of new headlights that are not pretty expensive. It would seem simple to separate the light assembly put it back together and use some type of waterproof sealant and not have to replace the whole light housing. Appreciate any comments that anyone might have. My 98 is the stock 2 door coupe with the 3800 engine.
Bill
bill2008 is offline   Reply With Quote Quick reply to this message
Old Feb 18th, 08, 09:02 PM   #2 (permalink)
Re: Can headlights for 98 Camaro be
Bill
Bill, I have to ask....why do they need to be cleaned? They should be sealed up tight where nothing gets in them. If you have condensation that means you have a crack.
If you really want to get them apart, you can do it without tearing them up. Follow these steps and you can do it yourself......
1. Remove headlights from the car. There is one 10mm bolt behind each headlight. Remove it, push in and slide the light towards the center of the car to remove it from the bracket. Turn the bulbs to remove them from the housing. Remove the four little silver clips holding the lense to the housing.
2. Heat up your oven to around 300 degrees. Stay by it the whole time when you're doing this step, so you do not accidently melt your headlights. Put in one headlight at a time on a piece of wood (so the metal grate does not melt the plastic). Leave in there for around 10 minutes. When you pull it out, it will be hot. Stick a flathead screwdriver or butterknife in between the housing and the lense and pry it apart. If it does not budge, heat it up more. Be very careful and go slow - the housing is very brittle and will break easily if you pry against it too hard. Once you have the lense seperated from the housing, clean off any old silicon that you can. It doesn't have to be perfect but the less old stuff that is on there, the better it will adhere.
3. Do your cleaning
4. Clean the housing with acetone (nail polish remover) or some kind of alcohol. Your fingerprints, old glue, etc must be cleaned off. Admire your work. Now's a good time to polish your lenses if they are hazy. When both parts are clean, you may put them back together. The easiest way to do this is to lay the housing face up on a flat surface. Fill the channel around it lavishly with silicon sealant. Lay the lense on top of it, and press down firmly, holding it like that for a minute or so. Reattach the silver clips and give the silicon enough time to set up!!
5. Now it's finished and ready for reassembly.
Hope this helps,
Joe
1969 Camaro....LS1/T-56.............
In the early stages of Pro-Touring
Kokamo is offline   Reply With Quote Quick reply to this message
Old Feb 19th, 08, 06:17 AM   #3 (permalink)
3. Do your cleaning
Hope this helps,
Joe
Joe,
Thanks so much for your reply. I will try this over the weekend. I will check for cracks as you mentioned, perhaps there is a crack on the part of the headlight that I can not see. do you know a source for a good replacement housing that is cheaper than buying OEM parts from the dealer?
Thanks again for your response, you have been very helpful.
Bill
Old Feb 19th, 08, 12:13 PM   #4 (permalink)
Joe,
Bill
Bill, no I don't man. But I will say that e-bay or craigslist can be your best friend.
Good luck,
Joe
Location
Location
First Name
» Recent Discussions
Door glass won't adjust...
Sep 14th, 19 01:02 PM
by ssanto
Last post by pittpens24
Today 05:54 AM
5 Replies, 164 Views
RPM stops at 3500 during...
Feb 28th, 16 09:07 PM
Last post by X-77 keith
Today 05:51 AM
7 Replies, 848 Views
Took home my 2nd Best in...
Yesterday 06:37 AM
Today 05:51 AM
9 Replies, 170 Views
Shock from horn
Aug 22nd, 19 06:59 AM
Last post by The Camaro Guy
Today 05:32 AM
15 Replies, 468 Views
Muncie shifting trouble
Yesterday 06:59 AM
Last post by R66
Today 05:31 AM
8 Replies, 170 Views
Adding...
Sep 15th, 19 05:57 AM
Last post by 350sshugger
Today 05:28 AM
9 Replies, 232 Views
Steering Arm Problem 68...
Sep 15th, 19 02:18 PM
Last post by R66
Today 05:18 AM
3 Replies, 162 Views
Kind of cool day for me
Aug 19th, 19 07:50 AM
Last post by rgwiz
Today 04:59 AM
24 Replies, 1,093 Views
carb tuning with...
Yesterday 08:47 AM
Last post by HawkX66
Today 04:49 AM
12 Replies, 159 Views
Coil Bracket
Today 03:34 AM
Last post by KevinW
Today 04:31 AM
2 Replies, 43 Views
