MAF sensor?? - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Mar 20th, 08, 11:29 AM   #1 (permalink)
MAF sensor??
Had a little situation happen to me at lunch. Just want to make sure i'm right about this before i unplug this faulty maf sensor of mine. here's the run down....
I have had my maf sensor unplugged for about 2 weeks now, cause when the car gets warm, the engine cuts in and out. With the sensor unplugged it doesn't cut out at all. only drinks a little more gas. I have a new maf sensor that i am putting in saturday. now for weird situation....
i was on lunch today. turned my car on, it started fine, put it in drive and gave a little gas and it stalled on me.... I started it back up, put it in drive and gave it gas and it kept stalling. Realized i was low on gas, but wasn't low enough for the gas light to come on yet.... So I plugged my faulty Maf back in and it car ran fine. got me to the gas station. My question is Does having the maf unplugged cause the gas light not to work, or is it just drinking so much gas because its unplugged that i was too close to empty??
facingxtinction is offline   Reply With Quote Quick reply to this message
Old Mar 27th, 08, 04:32 PM   #2 (permalink)
Re: MAF sensor??
Try this! Dirt build up on the sensing elements inside the sensor can cause all kinds of running problems. The simple fact that you unplugged it and the car uses more than normal gas is a good indication that there is your problem. Try this simple test! With the MAF plugged in and the car running use a screw driver and slightly tap the sensor. If the car stumbles or hesitates chances are it's bad. If the car runs normally and does not hesitate when you tap it then try cleaning the inside elements with contact cleaner. You can get this at any auto parts store. Are there any codes or check engine lights on?
LT1RUNNER is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
» Recent Discussions
Muncie shifting trouble
Yesterday 06:59 AM
Last post by R66
Today 05:31 AM
8 Replies, 165 Views
Adding...
Sep 15th, 19 05:57 AM
Last post by 350sshugger
Today 05:28 AM
9 Replies, 228 Views
Steering Arm Problem 68...
Sep 15th, 19 02:18 PM
Last post by R66
Today 05:18 AM
3 Replies, 159 Views
Kind of cool day for me
Aug 19th, 19 07:50 AM
Last post by rgwiz
Today 04:59 AM
24 Replies, 1,092 Views
Took home my 2nd Best in...
Yesterday 06:37 AM
Last post by rgwiz
Today 04:56 AM
8 Replies, 167 Views
carb tuning with...
Yesterday 08:47 AM
Last post by HawkX66
Today 04:49 AM
12 Replies, 157 Views
Coil Bracket
Today 03:34 AM
Last post by KevinW
Today 04:31 AM
2 Replies, 42 Views
Mid-pipes
Today 04:26 AM
Last post by bruce69camaro
Today 04:26 AM
0 Replies, 14 Views
Door glass won't adjust...
Sep 14th, 19 01:02 PM
by ssanto
Last post by johnpetty112
Today 12:17 AM
RPM stops at 3500 during...
Feb 28th, 16 09:07 PM
Today 12:14 AM
6 Replies, 839 Views
