Knocking in engine. - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Mar 27th, 08, 11:50 AM   #1 (permalink)
Knocking in engine.
I was driving to a buddy's house today and the motor developed a pretty loud knock. It happens in neutral around 1500rpm, and in gear around 2000 rpm. The odd thing to me though is, is that while in gear, If I put it in first, it happens at 2000rpm, in second, 2000rpm, in drive, not till 3000 rpm. Any ideas are welcome. The car is going to the shop in the morning but Im just trying to find some kind of relief I guess you could say. The car is a 1994 Z28 A4. Im thinking possibly a lifter noise of some kind, possibly rod knock, maybe bad flex plate, bad tourque converter? I have no idea but whatever it is Im hoping its not super expensive. Also, this should help, there is a fair amount of blow by comming up into the passenger side valve cover.
94TwitchZ28 is offline   Reply With Quote Quick reply to this message
Old Mar 27th, 08, 04:14 PM   #2 (permalink)
Re: Knocking in engine.
You may have a bad valve in the heads. Pull the valve covers and see if any valves are not bent or if there and no bent push rods.
LT1RUNNER is offline   Reply With Quote Quick reply to this message
Old Mar 29th, 08, 02:03 PM   #3 (permalink)
ok...pulled off the valve covers, loosened the rockers and inspected all of the pushrods. Took them inside and rolled them on the work bench, none are bent. As far as valves, Im not 100% sure on how to check that, but, from the looks of em, they seem to be going up and down, no side to side, no weird movement from them, I also dont really hear it in the valve covers, as well as I do on the top of the intake manifold. Im really starting to think lifter at this point. If I were to push on the pushrod, would a crush/collapsed lifter let the pushrod push in, or would it not move. Because thats what Im trying right now. Ill be back in, in about 15 minutes to post up what I found.
Location
Location
First Name
» Recent Discussions
RPM stops at 3500 during...
Feb 28th, 16 09:07 PM
Last post by X-77 keith
Today 05:51 AM
7 Replies, 847 Views
Took home my 2nd Best in...
Yesterday 06:37 AM
Last post by pittpens24
Today 05:51 AM
9 Replies, 170 Views
Door glass won't adjust...
Sep 14th, 19 01:02 PM
by ssanto
Today 05:49 AM
4 Replies, 162 Views
Shock from horn
Aug 22nd, 19 06:59 AM
Last post by The Camaro Guy
Today 05:32 AM
15 Replies, 468 Views
Muncie shifting trouble
Yesterday 06:59 AM
Last post by R66
Today 05:31 AM
8 Replies, 170 Views
Adding...
Sep 15th, 19 05:57 AM
Last post by 350sshugger
Today 05:28 AM
9 Replies, 231 Views
Steering Arm Problem 68...
Sep 15th, 19 02:18 PM
Last post by R66
Today 05:18 AM
3 Replies, 162 Views
Kind of cool day for me
Aug 19th, 19 07:50 AM
Last post by rgwiz
Today 04:59 AM
24 Replies, 1,093 Views
carb tuning with...
Yesterday 08:47 AM
Last post by HawkX66
Today 04:49 AM
12 Replies, 159 Views
Coil Bracket
Today 03:34 AM
Last post by KevinW
Today 04:31 AM
2 Replies, 43 Views
