Electric window problem - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Apr 21st, 08, 09:26 PM   #1 (permalink)
The drivers side window on my 1997 convertible is not operating correctly. You can push the switch and it will sart to move but will only go about half way and then stop. If you wait a few minutes it will move again but for a shorter time and so on. IF you wait a long time it will work a bit more.
I am assuming it is the relay or the switch heating up or overloading. I can hear a click from under the dash when I hit the switch so I am assuming the relay is down there some where.
Has anyone else ever had this problem and what did you do to fix it?
supv26 is offline   Reply With Quote Quick reply to this message
Old Apr 22nd, 08, 07:41 AM   #2 (permalink)
Re: Electric window problem
It is the motor. We just fixed one yesterday. Did the exact same thing. It moves a bit, gets warm, cools, moves a bit, gets warm, bla, bla, bla.
The motors are still available from GM
ProdigyCustoms is offline   Reply With Quote Quick reply to this message
Old Apr 22nd, 08, 09:36 PM   #3 (permalink)
Thumbs up Re: Electric window problem
Is it hard to replace? I am assuming I just remove the door panel and get to it from there...
Old Apr 24th, 08, 09:47 PM   #4 (permalink)
Look what a google search turned up for me!!
http://shbox.com/page/windowmotor.html
I stopped at Auto Zone and they have the window motor in stock for $59.17 and it has a limited lifetime warranty. I didn't price it at the dealership because I was told they only warranty them for 12 months.
Old Jun 7th, 08, 06:04 PM   #5 (permalink)
Replaced mine with an Autozone Motor works great and only takes about an hour an a half at most to replace, real easy to drill thru fiberglass. When the power motor is worn out and You try to use it then the curcuit breaker shuts off and You wait till the motor cools down and then it works again that is what happens. I think everybody who owns a fourth gen has replaced a window motor or two
edd Gordon is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
» Recent Discussions
15 inch rally wheel trim...
Sep 8th, 19 12:35 PM
Last post by BOOGIES
Today 08:40 AM
11 Replies, 271 Views
Replacing pinion seal &...
Jul 17th, 05 07:12 AM
Last post by Niblet
Today 08:24 AM
12 Replies, 16,236 Views
bucket seat lock latch...
Today 07:26 AM
Last post by aircavalryveteran
Today 07:26 AM
0 Replies, 21 Views
carb tuning with...
Sep 16th, 19 08:47 AM
Last post by bhodgdon400
Today 06:46 AM
21 Replies, 330 Views
Shock from horn
Aug 22nd, 19 06:59 AM
Last post by bondora68
Today 06:39 AM
18 Replies, 558 Views
Door Glass Doesn't Match...
Sep 14th, 19 05:48 AM
Last post by The Camaro Guy
Today 05:44 AM
12 Replies, 337 Views
Hello from Chicago
Yesterday 08:14 AM
Last post by Andrew69
Today 05:32 AM
3 Replies, 75 Views
Fuel line routing issue...
Sep 9th, 19 05:36 AM
by HawkX66
Last post by HawkX66
Today 04:37 AM
15 Replies, 376 Views
Took home my 2nd Best in...
Sep 16th, 19 06:37 AM
Last post by pittpens24
Today 04:18 AM
12 Replies, 239 Views
Humpday Humor, 9/17 ......
Yesterday 03:14 PM
Last post by flat tire
Today 04:10 AM
5 Replies, 148 Views
