95 3.4 security light always on - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Aug 17th, 08, 03:41 PM   #1 (permalink)
I have a '95 camaro 3.4 v6. the securty light is always on and i don't know why. the starts and runs fine bu the light is always on. any help would be great.
thanks
rmancl is offline   Reply With Quote Quick reply to this message
Old Aug 17th, 08, 05:17 PM   #2 (permalink)
Re: 95 3.4 security light always on
Robbie,
When you say it is "always" on, do you mean "always" or just when the ignition is on and the engine is running ? Is the light on solid or flashing ?
A loose connection at the ignition switch, or a bad switch, can let the BCM know that the correct key is in the ignition, but will make the light blink during run. The only way to know is to hook up an ohm meter and check the vats resistance throughout the entire movement of the key. It should stay the same. If it changes as you move the key, you have found the problem.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline   Reply With Quote Quick reply to this message
Old Aug 17th, 08, 05:26 PM   #3 (permalink)
its on when the key is in the on position and when the engine is running, the light stays on solid. I have been considering bypassing the VATS, is there an easy place to get to the wires so i can wire in a resistor?
If I bypass the VATS will the light go out?
Old Sep 2nd, 08, 07:07 PM   #4 (permalink)
any ideas?
Old Sep 3rd, 08, 03:17 AM   #5 (permalink)
Yes, you can do a Google search to find a couple ways to bypass/satisfy VATS. But in doing so will not allow VATS to do its job of anti-theft.
Old Sep 3rd, 08, 02:32 PM   #6 (permalink)
I'll bet one of the 2 small VATS orange and white wires coming from the ignition key cylinder is cut. It will still run if the failure occured when using the 'correct' key. But if you lost battery power you'd be S.O.L. Unfortuntaly you have to pull the steering wheel, air bag and some of the guts to fix it. It's not bad but it's time consuming.
1999 Lingenfelter H.O.S.S.
1969 Rally Grenn SS Camaro project (sold)
RIP John Lingenfelter
(Oct. 6, 1945 - Dec. 25, 2003)
tall guy is offline   Reply With Quote Quick reply to this message
Old Sep 3rd, 08, 08:21 PM   #7 (permalink)
actually i have had the battery removed several times. I have had this light on when the car is running ever since i got the car about a year ago. doesn't seem to cause any problems that i can tell though.
Location
Location
First Name
» Recent Discussions
Paint first or Motor...
Yesterday 04:43 PM
by AZ_Bill
Last post by HawkX66
Today 07:36 AM
6 Replies, 129 Views
What suspension kit for...
Yesterday 07:46 AM
by majj35
Last post by majj35
Today 07:30 AM
14 Replies, 191 Views
Original Spark Plugs for...
Today 07:29 AM
by Niblet
Last post by Niblet
Today 07:29 AM
0 Replies, 14 Views
Help! Weird noise near...
Yesterday 09:20 AM
by majj35
Last post by majj35
Today 07:29 AM
6 Replies, 140 Views
Distributor rebuild and...
Yesterday 11:45 AM
by CDB
Last post by Niblet
Today 07:25 AM
7 Replies, 168 Views
1969 Camaro...
Oct 18th, 19 03:02 PM
by BadCo69
Last post by railbrd9
Today 07:03 AM
23 Replies, 545 Views
Power window issue
Yesterday 07:56 PM
Last post by Everett#2390
Today 06:40 AM
1 Replies, 54 Views
MAP, MAT, MAP Vac
Today 05:41 AM
Last post by Sixty8Camaro
Today 06:30 AM
3 Replies, 49 Views
68 Camaro RS, Rear Diff...
Oct 19th, 19 06:38 PM
Today 06:19 AM
5 Replies, 137 Views
69 rustbucket rebirth
Jul 22nd, 13 11:38 AM
Last post by tp_smith
Today 05:32 AM
1 Replies, 188,208 Views
