98 3800 will not start - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old May 24th, 09, 11:57 AM   #1 (permalink)
Exclamation 98 3800 will not start
Battery has enough juice to fully power lights, interior lights, door chime, rear power hatch, and power door locks. No clicking, no fuel pump priming, no dash lights. I also noticed in the fuse block that the IGN fuse is missing. What perplexes me is that the car started and ran just fine 20 minutes prior.
Search function yielded a result of a bad water pump.
Please help quick. My car is parked in front of a closed store front, and I really dont want the car vandalized, stolen, or towed. Thanks all.
ricks4genshianne is offline   Reply With Quote Quick reply to this message
Old May 24th, 09, 12:04 PM   #2 (permalink)
SPARKY69's Avatar
Re: 98 3800 will not start
Jump it off...if you can turn on your lights and they go out when you try to crank it your batt is dead or you have a loose connection!!
SPARKY69 is offline   Reply With Quote Quick reply to this message
Old May 24th, 09, 12:17 PM   #3 (permalink)
already did that check. Lights stayed solid the whole time trying to crank.
I did forget to mention that we tried to pop the clutch, but that didnt do anything for us.
Old May 24th, 09, 12:20 PM   #4 (permalink)
SPARKY69's Avatar
Check your switch at the bottom of the pedal(clutch) to see if its is engaging!! Do you hear your fuel pump running while you turn the key on? Pump might be bad or out of gas!!
Old May 24th, 09, 12:23 PM   #5 (permalink)
Skeeter55's Avatar
What about that IGN fuse... Some where the main IGN fuse is not linked to power..
I NEED TO HIT THE LOTTERY
Skeeter55 is offline   Reply With Quote Quick reply to this message
Old May 24th, 09, 12:24 PM   #6 (permalink)
no pump priming that I heard. I will hafta get back to the car and take a look at the clutch switch.
Old May 24th, 09, 12:25 PM   #7 (permalink)
SPARKY69's Avatar
you might want to take off the air intake hose and squirt some carb cleaner into the throttle body while you have a buddy crank it over!! if it runs your fuel pump is bad!!
Old May 24th, 09, 12:27 PM   #8 (permalink)
Skeeter55's Avatar
No dash lights, its gotta be in the IGN switch...
Old May 24th, 09, 12:28 PM   #9 (permalink)
SPARKY69's Avatar
good call
Old May 24th, 09, 12:28 PM   #10 (permalink)
thats what the other site I use is leaning towards, as well. How difficult is it to replace the ign sw?
Old May 24th, 09, 12:29 PM   #11 (permalink)
Skeeter55's Avatar
Bill he said its not cranking... It has to be a fuse IGN fuse.. Or IGN switch
Old May 24th, 09, 12:31 PM   #12 (permalink)
SPARKY69's Avatar
rick, when you turn your car over do you hear the starting engaging??
Old May 24th, 09, 12:39 PM   #13 (permalink)
No, Bill, the car does NOTHING but *ding* at me right now.
Old May 24th, 09, 12:43 PM   #14 (permalink)
does ANYONE know where I can find an IGN fuse for the in-car fuse block? The slot is shaped like 2 L linked together by the lower bar. ummm, as in:
LL
now reverse the second L to face the first. After they're mirror images, invert the second L so the "mast" is pointing down. One the fuse panel door, it shows an image of a upside-down L. WTF is that crazy effin fuse? How do I get one of them?
Old May 24th, 09, 12:43 PM   #15 (permalink)
SPARKY69's Avatar
Double check all you fuse's in the car with a test light..make sure the switch on the back of the clutch pedal is still hooked up and you did not knock it out of adjustment!! Lean towards the ignition being bad if all else is good!!
Location
Location
First Name
» Recent Discussions
What suspension kit for...
Yesterday 07:46 AM
by majj35
Last post by KJProX
Today 07:07 AM
13 Replies, 185 Views
1969 Camaro...
Oct 18th, 19 03:02 PM
by BadCo69
Last post by railbrd9
Today 07:03 AM
23 Replies, 533 Views
Power window issue
Yesterday 07:56 PM
Last post by Everett#2390
Today 06:40 AM
1 Replies, 51 Views
MAP, MAT, MAP Vac
Today 05:41 AM
Last post by Sixty8Camaro
Today 06:30 AM
3 Replies, 46 Views
Paint first or Motor...
Yesterday 04:43 PM
by AZ_Bill
Last post by scblucam
Today 06:28 AM
5 Replies, 119 Views
Help! Weird noise near...
Yesterday 09:20 AM
by majj35
Today 06:25 AM
5 Replies, 133 Views
68 Camaro RS, Rear Diff...
Oct 19th, 19 06:38 PM
Today 06:19 AM
5 Replies, 134 Views
69 rustbucket rebirth
Jul 22nd, 13 11:38 AM
Last post by tp_smith
Today 05:32 AM
1 Replies, 188,199 Views
Newbie has several...
Aug 10th, 19 08:18 AM
by Go4Gold
Last post by parkbrau
Today 05:32 AM
65 Replies, 2,828 Views
Back again...this time...
Yesterday 12:32 PM
by fuffl
Last post by buenymayor
Today 05:18 AM
1 Replies, 74 Views
