3.4L wont start..... - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Jul 19th, 09, 03:49 PM   #1 (permalink)
Unhappy 3.4L wont start.....
when i turn the key it doesnt click or anything.. normal otherwise.
it started fine just minutes before, now nothing.
it DID kinda drag the other day when i was starting it though.
could it be the solinoid or possibly the relay switch?
where is the relay located?
my friend tried to push start it, but it didnt work.....????
im new to camaros, but im good with motors, id greatly
appreciate any help with this as its stuck at the store
down the street right now...thx...zimmmy
zimmyjim is offline   Reply With Quote Quick reply to this message
Old Jul 20th, 09, 04:15 AM   #2 (permalink)
SPARKY69's Avatar
Re: 3.4L wont start.....
Did you try charging the battery or jumping it off??
SPARKY69 is offline   Reply With Quote Quick reply to this message
Old Jul 20th, 09, 06:45 AM   #3 (permalink)
im going to try that first thing this morning, although it didnt seem to be dead....z
Old Jul 20th, 09, 08:06 AM   #4 (permalink)
battery is at 12.47 volts...jumped it and nothing happened.
i also tried to jump the starter with a wire and got a little whirring sound but i couldnt tell what connection i was touching on the solinoid.
it didnt try to turn the motor though.
ill be heading down to pull the starter if i dont get any suggestions in the next 30 minutes or so.....zimmmmy
Old Jul 20th, 09, 08:07 AM   #5 (permalink)
SPARKY69's Avatar
did you check all your fuses? maybe main fuse is blown..
Old Jul 20th, 09, 08:32 AM   #6 (permalink)
i checked all the fuses on the drivers end of the dash and the fuses in the black box next to the air filter...are there any im missing? where is the main fuse located?
also, is there a relay for my starter?...........z
Old Jul 20th, 09, 08:35 AM   #7 (permalink)
btw...shouldnt i be able to push start it in second?
i tried that yesterday but it wouldnt start.......z
Old Jul 20th, 09, 08:38 AM   #8 (permalink)
SPARKY69's Avatar
do you have any power to anything with the key on??i dont see anywhere you have posted. what year is your car??
Old Jul 20th, 09, 09:01 AM   #9 (permalink)
its a 95...everything else seems to be working, dash lights come on like they normally do.
the courtesy fuse is blowed, but i guess its always been that way....i switched it out and the door started ding ding dingin and the security light came on so i took it back out.
Old Jul 20th, 09, 11:16 AM   #10 (permalink)
update....
when i run a hot wire to the starter it spins but doesnt enagage...so i ran a test light from the small connection on the solinoid and turned the key and didnt get any light.
from what ive been told, if the test light doesnt work and it cant be push started, then the ignition switch is faulty.
i think my steering wheel has been pulled before because the tires arent straight when the steering wheel is centered. im told a new ignition is $1000!
i could buy a whole car for that!
gee whiz! anybody know how to hot wire my car???? ...z
Old Jul 22nd, 09, 07:36 PM   #11 (permalink)
well, i talked to a locksmith today and he said that it was most likely the little wires going to the ignition cylinder so i dug up a variable resistor, set it to the exact ohmage setting as the key, cut the wires in the orange wrap coming outta the steering column, wired in my resistor, and VROOM, started right up!
hope this info helps some other poor guy thats had his car setting in the yard for 6 months wondering why it wont start ............zimmmy
btw....a new ignition cylinder is only around $30
Old Aug 19th, 09, 07:51 AM   #12 (permalink)
i'm sure it would help the others. nice info.
richkcmo is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
» Recent Discussions
Power window issue
Yesterday 07:56 PM
Last post by Everett#2390
Today 06:40 AM
1 Replies, 49 Views
MAP, MAT, MAP Vac
Today 05:41 AM
Last post by Sixty8Camaro
Today 06:30 AM
3 Replies, 42 Views
Paint first or Motor...
Yesterday 04:43 PM
by AZ_Bill
Last post by scblucam
Today 06:28 AM
5 Replies, 112 Views
Help! Weird noise near...
Yesterday 09:20 AM
by majj35
Today 06:25 AM
5 Replies, 130 Views
68 Camaro RS, Rear Diff...
Oct 19th, 19 06:38 PM
Today 06:19 AM
5 Replies, 131 Views
What suspension kit for...
Yesterday 07:46 AM
by majj35
Last post by majj35
Today 06:14 AM
12 Replies, 180 Views
69 rustbucket rebirth
Jul 22nd, 13 11:38 AM
Last post by tp_smith
Today 05:32 AM
1 Replies, 188,198 Views
Newbie has several...
Aug 10th, 19 08:18 AM
by Go4Gold
Last post by parkbrau
Today 05:32 AM
65 Replies, 2,828 Views
Back again...this time...
Yesterday 12:32 PM
by fuffl
Last post by buenymayor
Today 05:18 AM
1 Replies, 72 Views
New member
Yesterday 07:42 PM
Today 05:16 AM
1 Replies, 44 Views
