1995 OBDII Problem & IAC Valve Bad????? - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Aug 19th, 09, 01:12 PM   #1 (permalink)
OK, working on a new project. Here is my problem: 1995 3.4L automatic recently the idle has been running around 1200-1300 rpms. Pulled the IAC cleaned it off, checked it with the meter. Manual says terminal A to B and C to D should read 40-80 ohms. Both readings are exactly 40. After the car idles for a few minutes, rpm increases to 1500 and SES light comes on. Go to hook up my OBDII code reader and get an error message. I am sure the reader works fine, but this is the first time I have used it on this car. I am getting power to the unit, but it will not read the cars PCM. So, I need help determining if there is something else causing my idle increase and why I can't read codes.
Xcelr8 is offline   Reply With Quote Quick reply to this message
Old Aug 19th, 09, 05:52 PM   #2 (permalink)
Re: 1995 OBDII Problem & IAC Valve Bad?????
95's are tough.
Many 1995 GM cars had the ODB2 diagnotsic connector..., but...
These are absolutely ODB ONE cars. I have run into this twice, without success both tims, weren't my cars so, ya know, trying and fialing is OK.
ODB2 did not start until 1996. you need an ODB1 scanner and some sort of adapter cable.
You should be able to search the right pins to short to get the SES light to blink your codes.
JimM is offline   Reply With Quote Quick reply to this message
Old Aug 20th, 09, 08:34 PM   #3 (permalink)
Just an update on my idle problem. After searching some posts I came across a suggestion to check the vacuum lines to the intake manifold and sure enough, the rubber section between the PCV valve and the hard line had a hole in it. Cut a new piece of 3/8" line, plugged it back in, fired her up and the idle was right around 600. Unfortunately I had already messed around with the idle set screw before I knew what the problem was, so that will have to be bumped back up to make it right.
Location
Location
First Name
» Recent Discussions
Sniper install!!!!
Mar 16th, 18 07:22 AM
Last post by OUTarHeel
Today 08:16 AM
8 Replies, 1,551 Views
Paint first or Motor...
Yesterday 04:43 PM
by AZ_Bill
Last post by HawkX66
Today 07:36 AM
6 Replies, 129 Views
What suspension kit for...
Yesterday 07:46 AM
by majj35
Last post by majj35
Today 07:30 AM
14 Replies, 192 Views
Original Spark Plugs for...
Today 07:29 AM
by Niblet
Last post by Niblet
Today 07:29 AM
0 Replies, 16 Views
Help! Weird noise near...
Yesterday 09:20 AM
by majj35
Last post by majj35
Today 07:29 AM
6 Replies, 141 Views
Distributor rebuild and...
Yesterday 11:45 AM
by CDB
Last post by Niblet
Today 07:25 AM
7 Replies, 170 Views
1969 Camaro...
Oct 18th, 19 03:02 PM
by BadCo69
Last post by railbrd9
Today 07:03 AM
23 Replies, 545 Views
Power window issue
Yesterday 07:56 PM
Last post by Everett#2390
Today 06:40 AM
1 Replies, 55 Views
MAP, MAT, MAP Vac
Today 05:41 AM
Last post by Sixty8Camaro
Today 06:30 AM
3 Replies, 50 Views
68 Camaro RS, Rear Diff...
Oct 19th, 19 06:38 PM
Today 06:19 AM
5 Replies, 137 Views
