96 z28 fuel pump - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Feb 9th, 10, 10:42 AM   #1 (permalink)
96 z28 fuel pump
How hard is it to replace a fuel pump in a 96 z28?
DAJz28 is offline   Reply With Quote Quick reply to this message
Old Feb 9th, 10, 10:47 AM   #2 (permalink)
SPARKY69's Avatar
Re: 96 z28 fuel pump
not bad ,about 4 hrs worth of work ,drop the exhaust and rear suspension and the tank and your good to go!..a lift makes life easier!
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline   Reply With Quote Quick reply to this message
Old Feb 12th, 10, 05:13 PM   #3 (permalink)
you have two choices
1. drop the gas tank like sparky said
or
2. cut an access panel in the trunk to expose the fuel pump assembly.
if you want to do it the right way, you will have to drop the tank, but most people cut the access panel, and it only takes maybe 30min to do that and install the new fuel pump.
you can just bend the metal back and put some tape over it.
victimizati0n is offline   Reply With Quote Quick reply to this message
Old Feb 12th, 10, 08:38 PM   #4 (permalink)
i did it in 30 min on a rack easy but i have done alot of these cars and know what to do thats why i can do them fast , i would not cut the car
"Well, the trouble with our liberal friends is not that they are ignorant, but that they know so much that isn't so." -- Ronald Reagan
67CAMAROSS is offline   Reply With Quote Quick reply to this message
Old Feb 13th, 10, 09:38 PM   #5 (permalink)
I hate the fact that GM did not put a Access panel for the fuel pump !!!! what were they thinking that it would never go out ???
they are a pain in the Butt to do the right way which would be dropping the tank .. but nobody said here to try and get a friend and help you with the tank when it comes down and when putting it back in .. the filler neck is trickey going back in.
RobSS1113 is offline   Reply With Quote Quick reply to this message
Old Apr 6th, 10, 11:23 PM   #6 (permalink)
dont take apart the rear end, cut the access panel and patch it back up. work smarter not harder. google cutting the fuel pump access panel and its all right there.
EVOGASM is offline   Reply With Quote Quick reply to this message
Old Apr 7th, 10, 12:40 AM   #7 (permalink)
If you do it the right way, make sure you get as much gas out of the tank as possible before you try to drop the tank. Once the tank comes loose, all that gas will start sloshing around and make it hard to handle.
buenymayor is online now   Reply With Quote Quick reply to this message
Old Apr 7th, 10, 05:41 PM   #8 (permalink)
what do you consider the right way. dude dont listen to this guy, go to this website and do this. took me 45 mins start to finish and pump done. pm me if you need more info or where to get a great 255 lph pump for 79.98 shipped. i know a great vendor for them. drop the tank lol.
www.worldisround.com/articles/12533/index.html
Old Apr 8th, 10, 02:56 AM   #9 (permalink)
Before tearing into the car, confirm the fuel pump relay is working. If the pump isn't getting voltage, it won't run. Also, if you need to move the car to an easier place to work on it, sometimes you can smack the gas tank and it will jar the pump enough so will run.
Old Nov 2nd, 11, 09:28 AM   #10 (permalink)
I have what i think is a bad pump on a 98 RS.
I have checked the fuel pump relay and even jumperd it out but still not pump.
I have 3 connectors where the pump, sending unit and diff slip indicator plug in.
Just above it there is a black box a bit bigger then a pack of cigarettes that is wired into the harness going to the top of the tank.
The car qtraversing a 30 to 40 deg incline.
I know Ford has a shut off switch that will kill the fuel punp should the car impact , does the camaro have a same featyre and would that black box be it?
I did read viltage to the one connector that has only 2 wires going to it but are coulored differently then the manual.
the other connector has 7 wires and then the diff slip sencor.
Any help before i go cutting the hump to pull a pump that may still be good.
sarah01 is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
» Recent Discussions
Sniper install!!!!
Mar 16th, 18 07:22 AM
Last post by OUTarHeel
Today 08:16 AM
8 Replies, 1,556 Views
Paint first or Motor...
Yesterday 04:43 PM
by AZ_Bill
Last post by HawkX66
Today 07:36 AM
6 Replies, 132 Views
What suspension kit for...
Yesterday 07:46 AM
by majj35
Last post by majj35
Today 07:30 AM
14 Replies, 194 Views
Original Spark Plugs for...
Today 07:29 AM
by Niblet
Last post by Niblet
Today 07:29 AM
0 Replies, 21 Views
Help! Weird noise near...
Yesterday 09:20 AM
by majj35
Last post by majj35
Today 07:29 AM
6 Replies, 142 Views
Distributor rebuild and...
Yesterday 11:45 AM
by CDB
Last post by Niblet
Today 07:25 AM
7 Replies, 170 Views
1969 Camaro...
Oct 18th, 19 03:02 PM
by BadCo69
Last post by railbrd9
Today 07:03 AM
23 Replies, 547 Views
Power window issue
Yesterday 07:56 PM
Last post by Everett#2390
Today 06:40 AM
1 Replies, 55 Views
MAP, MAT, MAP Vac
Today 05:41 AM
Last post by Sixty8Camaro
Today 06:30 AM
3 Replies, 52 Views
68 Camaro RS, Rear Diff...
Oct 19th, 19 06:38 PM
Today 06:19 AM
5 Replies, 138 Views
