95 camaro no pwr to fuel pump. need help - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Mar 20th, 10, 05:48 AM   #1 (permalink)
does anyone know is there fuel pump relay.im getting intermittant pwr to pump.
95camaroman is offline   Reply With Quote Quick reply to this message
Old Apr 6th, 10, 11:16 PM   #2 (permalink)
Re: 95 camaro no pwr to fuel pump. need help
your fuel pump relay is behind the plastic piece to the left of your clutch pedal where your hood popper is. if you remove that you cant miss the relay. let me know if you find it and that fixes your issue.
EVOGASM is offline   Reply With Quote Quick reply to this message
Old Nov 9th, 11, 01:52 PM   #3 (permalink)
i got no power to my fuel pump and cannot figure out why, changed the realay and still nothing...
mud4594 is offline   Reply With Quote Quick reply to this message
Old Nov 9th, 11, 01:53 PM   #4 (permalink)
can anybody help me
Old Nov 10th, 11, 06:54 PM   #5 (permalink)
prostreet69camaro's Avatar
I commented here. Dont know if it helps though.
https://www.camaros.net/forums/showthread.php?t=201576
prostreet69camaro is offline   Reply With Quote Quick reply to this message
Old Nov 11th, 11, 05:06 AM   #6 (permalink)
When you first turn on the key, the fuel pump should run for just a second and shut off. Then when you crank, the crank sensor and cam sensors should send timing pulses to the ECM which will turn on the ignition power and fuel pump.
So if you find the pump does the 1 second prime (which it doesn't seem to do for every turn of the key for some reason) but the pump won't run during crank, look into the crank and cam sensors.
dnult is offline   Reply With Quote Quick reply to this message
Old Nov 11th, 11, 06:24 AM   #7 (permalink)
I would suspect what Dave said is the problem.
Location
Location
First Name
» Recent Discussions
Sniper install!!!!
Mar 16th, 18 07:22 AM
Last post by OUTarHeel
Today 08:16 AM
8 Replies, 1,553 Views
Paint first or Motor...
Yesterday 04:43 PM
by AZ_Bill
Last post by HawkX66
Today 07:36 AM
6 Replies, 131 Views
What suspension kit for...
Yesterday 07:46 AM
by majj35
Last post by majj35
Today 07:30 AM
14 Replies, 194 Views
Original Spark Plugs for...
Today 07:29 AM
by Niblet
Last post by Niblet
Today 07:29 AM
0 Replies, 20 Views
Help! Weird noise near...
Yesterday 09:20 AM
by majj35
Last post by majj35
Today 07:29 AM
6 Replies, 142 Views
Distributor rebuild and...
Yesterday 11:45 AM
by CDB
Last post by Niblet
Today 07:25 AM
7 Replies, 170 Views
1969 Camaro...
Oct 18th, 19 03:02 PM
by BadCo69
Last post by railbrd9
Today 07:03 AM
23 Replies, 547 Views
Power window issue
Yesterday 07:56 PM
Last post by Everett#2390
Today 06:40 AM
1 Replies, 55 Views
MAP, MAT, MAP Vac
Today 05:41 AM
Last post by Sixty8Camaro
Today 06:30 AM
3 Replies, 51 Views
68 Camaro RS, Rear Diff...
Oct 19th, 19 06:38 PM
Today 06:19 AM
5 Replies, 138 Views
