95 v-6 swap to sbc 400 - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Jun 18th, 10, 10:31 PM   #1 (permalink)
I'm looking at swapping out my 3.4 v6 for a sbc 400. I am putting all forged internals into it and boring the block out .030 over 3.75 crank throw and 6 inch connecting rods shorter pistons. It looks like I'm going to be running about 11.5:1 compression and going to be around 430 cid after everything.
I'm thinking I want to twin turbo the block once I map out the fuel and spark but I am worried that the blocks not going to fit inside the engine bay. Also im not looking at prices I already know this is going to be expensive and time consuming I just would like to know id the block would hold up to twin turbos.
Any comment would help a lot.
Chevyrock83 is offline   Reply With Quote Quick reply to this message
Old Jun 20th, 10, 09:42 PM   #2 (permalink)
Re: 95 v-6 swap to sbc 400
hope it don't have a distributer these cars are made for dis systems no firewall room for a distributer thats why they used lt1 and the ls1 in later years
"Well, the trouble with our liberal friends is not that they are ignorant, but that they know so much that isn't so." -- Ronald Reagan
67CAMAROSS is offline   Reply With Quote Quick reply to this message
Old Jun 21st, 10, 03:23 AM   #3 (permalink)
The block, 400 CID, might work if prepped correctly, and not overrevved if equipped with stock parts. A said, going into a '95, a Gen I V8 would be a tight fit, considering the lack of space for conventional Kettering ignition.
I would drop the comp ratio as turbocharging makes up for it.
Alum heads, aftermarket block, forged internals, and a DIS system.
If it were me, I'd start with a LQ9 engine and go from there.
Good luck in your endeavor - welcome to the club, Carl.
Old Jun 21st, 10, 03:26 AM   #4 (permalink)
SPARKY69's Avatar
welcome to team camaro!!
do a search here on engine swaps..it takes a bit more than you think..it can be done though!!
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline   Reply With Quote Quick reply to this message
Old Jun 24th, 10, 12:15 PM   #5 (permalink)
in order to do that swap, you will need the following:
- new k member (bmr makes them)
- new trans crossmember (bmr makes them)
- fuel pump
- low intake manifold
- cutting the cowl area (the low intake helps, if you want ot put a hi rise on, you will need to cut the cowl so much you will loose the wipers)
- new radiator (ls1 may work, but i would be a bit afraid with the engine you want to build)
the price actually isnt that bad... around $2000 all said and done minus the engine and transmission.
- LT1 headers (will fit a sbc)
victimizati0n is offline   Reply With Quote Quick reply to this message
Old Jun 28th, 10, 08:41 AM   #6 (permalink)
- fuel pump
The lt1 headers will work on a sbc then? And what about an oil pan? I just don't want to buy one that's not gonna clear the frame or that's gonna be to low to the pavement.
Old Jun 28th, 10, 11:35 AM   #7 (permalink)
the lt1 headers will work fine, the best thing is you dont have to get a custom set made.
the oil pan will work as long as you are using a 1 piece rear main seal engine. im not too sure how exactly it would work if your engine has a 2 piece rear main. if you are getting the aftermarket k member, i would imagine a stock pan would clear with no problems
Location
Location
First Name
» Recent Discussions
awaiting spring
Yesterday 04:00 AM
Last post by allanjs
Yesterday 08:23 PM
13 Replies, 158 Views
Over Drive Trans or...
Oct 19th, 19 06:19 AM
Last post by mahunt
Yesterday 08:06 PM
6 Replies, 134 Views
Where did everyone go?
Oct 13th, 19 08:07 PM
Yesterday 08:05 PM
62 Replies, 1,840 Views
Narrowing a Impala 12...
Aug 2nd, 19 01:00 PM
by X1169B
Last post by mahunt
Yesterday 08:04 PM
16 Replies, 867 Views
BBC water bypass line
Oct 19th, 19 07:12 PM
by Foss396
Last post by Lonnie P
Yesterday 07:20 PM
12 Replies, 190 Views
Success and failures...
Yesterday 06:56 PM
Last post by Cunning69
Yesterday 07:03 PM
1 Replies, 43 Views
Just why ?
Oct 19th, 19 04:34 PM
by DOUG G
Last post by stevo camaro
Yesterday 06:58 PM
6 Replies, 227 Views
Backyard buried...
Apr 5th, 05 04:12 PM
Yesterday 06:55 PM
1 Replies, 183,877 Views
Quiet High Performance...
Oct 18th, 19 07:18 PM
Last post by kv67ssrs
Yesterday 06:30 PM
6 Replies, 196 Views
Need the carb guy's
Yesterday 05:55 PM
Yesterday 06:15 PM
2 Replies, 56 Views
