96 Camaro Air Conditioner Temperature Question - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Jun 29th, 10, 01:19 PM   #1 (permalink)
I have a V6, 1996 Camaro that is blowing air out at about 64 degrees when the air temperature is about 86. Low pressure side checks out at 50 PSI with A/C on Max blowing full even after 10 minutes. I noticed that the high pressure side valve and tube is warm, not hot to the touch.
Am I asking too much for the A/C to be blowing a little more cooler? Seems I read somewhere that the Low pressure side and high pressure side should be about the same temperature to the touch. Maybe I dreamt it. I think I may be spoiled by my 2002 S10 that blows out 50 degree air.
Should it be cooler?
RSFish1 is offline   Reply With Quote Quick reply to this message
Old Jun 29th, 10, 01:37 PM   #2 (permalink)
Smile Re: 96 Camaro Air Conditioner Temperature Question
Low side - suction side- should be cold to the touch.
Hi side - should be hot - you shouldn't be able to keep your hand on it.
TJS69 is offline   Reply With Quote Quick reply to this message
Old Jun 29th, 10, 05:33 PM   #3 (permalink)
Set a box fan in front of the car to help 'cool' the condensor.
Lower the blower speed one notch, the slower the air blown, the more the transfer of heat.
Wife's Element in today's 95 heat blew only 60 with outside air selected.
Old Jun 29th, 10, 05:56 PM   #4 (permalink)
should be pushin low 50s, check the condiser for blockage. leaves, grass, etc etc. if its not that the condser might have a restirction, 50 psi on the low side is kinda high but not terrible, whats the psi on the high side? are you using gauges or the dinky top off dealy that comes with cans of freon?
1967 Camaro RS
383 Stroker 427HP 457TQ
Tremec TKO-600
Strange Engineering 12-Bolt 4.11 Posi
Coys C-55 18" Wheels
Scott MH is offline   Reply With Quote Quick reply to this message
Old Jun 29th, 10, 06:03 PM   #5 (permalink)
He's probably using one of those gauge-on-a-can for the suction side. Personnel/operator safety.
Old Jun 29th, 10, 06:38 PM   #6 (permalink)
Send a message via AIM to zbo2
the low side should be around 35 psi w/134...fan and a/c on max..........if you start gettin towards 40 psi they start warmin up....(overcharged)...........you should check the temps runnin down the road after you get the interior cooled off a little.
Joe
69 Z-28 Fathom Green />93 Z-28 Pace Car/>86 Corvette...Red
zbo2 is offline   Reply With Quote Quick reply to this message
Old Jun 30th, 10, 04:12 AM   #7 (permalink)
i used to say the same thing but i came accross a honda civic that would not cool unless the low side was in the upper 40s. craziest thing, more than likely it had some parts that needed to be replaced but the owner didnt want to spend the money, didnt even want to pay for the freon.
but yeah a standard, system should be running around 35 low and 150 hi, but unless you have gauges dont bother trying to read the high, you might blow up the can. in fact, take it to a a/c repair shop.
1967 Camaro RS
Tremec TKO-600
Location
Location
First Name
» Recent Discussions
Paint first or Motor...
Yesterday 04:43 PM
by AZ_Bill
Last post by HawkX66
Today 07:36 AM
6 Replies, 127 Views
What suspension kit for...
Yesterday 07:46 AM
by majj35
Last post by majj35
Today 07:30 AM
14 Replies, 189 Views
Original Spark Plugs for...
Today 07:29 AM
by Niblet
Last post by Niblet
Today 07:29 AM
0 Replies, 8 Views
Help! Weird noise near...
Yesterday 09:20 AM
by majj35
Last post by majj35
Today 07:29 AM
6 Replies, 138 Views
Distributor rebuild and...
Yesterday 11:45 AM
by CDB
Last post by Niblet
Today 07:25 AM
7 Replies, 166 Views
1969 Camaro...
Oct 18th, 19 03:02 PM
by BadCo69
Last post by railbrd9
Today 07:03 AM
23 Replies, 541 Views
Power window issue
Yesterday 07:56 PM
Last post by Everett#2390
Today 06:40 AM
1 Replies, 52 Views
MAP, MAT, MAP Vac
Today 05:41 AM
Last post by Sixty8Camaro
Today 06:30 AM
3 Replies, 48 Views
68 Camaro RS, Rear Diff...
Oct 19th, 19 06:38 PM
Today 06:19 AM
5 Replies, 135 Views
69 rustbucket rebirth
Jul 22nd, 13 11:38 AM
Last post by tp_smith
Today 05:32 AM
1 Replies, 188,205 Views
