94 LT1 Trans Am idle problem - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Jul 20th, 10, 04:03 AM   #1 (permalink)
My sister has a 94 anniversary edition TA that the idle is a little erratic after it gets up to temp. I put a new throttle position sensor in it but it still has the same problem. The ses light comes on once in a while but goes off. The car just passed emissions with flying colors, any ideas? The car only has 91K miles on it and I think she is going to be selling it soon if anyone is interested. It's a t top car not perfect but a nice car.
69blownprostreet is offline   Reply With Quote Quick reply to this message
Old Jul 20th, 10, 07:51 AM   #2 (permalink)
Send a message via AIM to Satatic
Re: 94 LT1 Trans Am idle problem
If its getting up to temp then going to crap try unplugging both the front 02 sensors. If you never see the problem after that then there you go. 02 sensors have become one of the first things I check anymore. Replace with AC Delco, bosch are garbage.
Satatic is offline   Reply With Quote Quick reply to this message
Old Jul 20th, 10, 01:07 PM   #3 (permalink)
Thanks I'll try that. The idle isn't real crazy it will go from about 600 rpm up to 1000-1100 then go back to 600. It's still driveable but when your at a stop light waiting and it goes up it feels like it's trying to take off on you so i'll try that and post what happens.
Old Jul 20th, 10, 08:43 PM   #4 (permalink)
If you run by AutoZone or somewhere like that they may be able to pull the old stored codes out of it for you with an OBD-I scanner and maybe give some direction. I believe an EGR malfunction will set a light and then clear it on its own. If the EGR valve plunger is sticking or has carbon buildup in the hole it acts like a vacuum leak which can cause funkiness. Also, the plastic/rubber air intake elbows after the MAF sensor going to the throttle body are prone to getting rips which also act like a vacuum leak.
'69 Camaro
500hp/538lbft
Steiner is offline   Reply With Quote Quick reply to this message
Old Jul 28th, 10, 03:44 AM   #5 (permalink)
you are correct. the best way to tell if its the EGR is to go down a hill and engine brake, it will set a code if its bad
victimizati0n is offline   Reply With Quote Quick reply to this message
Old Jul 28th, 10, 03:38 PM   #6 (permalink)
Take a good look at the hose connecting the pcv valve to the throttle body.They collapse and split over time when exposed to crankcase vapor.
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline   Reply With Quote Quick reply to this message
Old Jul 30th, 10, 06:54 AM   #7 (permalink)
Thanks for all the help, I'm going to check all that stuff out later today or tomorrow. Haven't had time yet.
Location
Location
First Name
» Recent Discussions
awaiting spring
Yesterday 04:00 AM
Last post by allanjs
Yesterday 08:23 PM
13 Replies, 158 Views
Over Drive Trans or...
Oct 19th, 19 06:19 AM
Last post by mahunt
Yesterday 08:06 PM
6 Replies, 135 Views
Where did everyone go?
Oct 13th, 19 08:07 PM
Yesterday 08:05 PM
62 Replies, 1,841 Views
Narrowing a Impala 12...
Aug 2nd, 19 01:00 PM
by X1169B
Last post by mahunt
Yesterday 08:04 PM
16 Replies, 869 Views
BBC water bypass line
Oct 19th, 19 07:12 PM
by Foss396
Last post by Lonnie P
Yesterday 07:20 PM
12 Replies, 191 Views
Success and failures...
Yesterday 06:56 PM
Last post by Cunning69
Yesterday 07:03 PM
1 Replies, 44 Views
Just why ?
Oct 19th, 19 04:34 PM
by DOUG G
Last post by stevo camaro
Yesterday 06:58 PM
6 Replies, 228 Views
Backyard buried...
Apr 5th, 05 04:12 PM
Yesterday 06:55 PM
1 Replies, 183,879 Views
Quiet High Performance...
Oct 18th, 19 07:18 PM
Last post by kv67ssrs
Yesterday 06:30 PM
6 Replies, 196 Views
Need the carb guy's
Yesterday 05:55 PM
Yesterday 06:15 PM
2 Replies, 56 Views
