1993 3.4L running very poorly - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Jun 23rd, 13, 06:59 PM   #1 (permalink)
Post 1993 3.4L running very poorly
so here's some backstory before i get to the problem.
What i have done to the car:
  • new spark plugs and wires
  • new O2 sensors
  • new EGR valve
  • new IAC valve
  • new TPS
  • K&N FIPK Intake
  • Flowmaster Natural 44 series muffler
  • new PCV
  • new water pump
  • recent oil change
now that that's out of the way, my problem is that when i'm driving, the car has no problem getting through first gear, but once i get into second the engine will bog down and wont get past 3000rpm. i'll floor it and nothing will change, it will just sputter and try to stall. i'm getting OBD error codes 43 (i believe that's the knock sensor) and 77 (i think that's the cooling fan control relay circuit). i have no idea what those would have to do with the symptoms i'm experiencing, but every time i drive and the SES light comes on, those are the codes it gives me. i only noticed the problem recently after replacing the O2 sensors and spark plugs/wires, so unless anyone else has another idea i'll probably start by checking those to make sure i didn't jack something up.
Thanks in advance for any help!
rcspohr is offline   Reply With Quote Quick reply to this message
Old Jun 24th, 13, 04:44 PM   #2 (permalink)
Re: 1993 3.4L running very poorly
here's an update on the situation, just in case anyone else has the same problem and can't find an answer. i took out my o2 sensors to see if they were the actual problem, and while driving around i still had the same symptoms. because of this, i'm going to assume that my problem is the catalytic converter is clogged up. so i'm gonna take the $300 risk of buying a high flow cat and putting that on. I'll report as to what happens.
Old Jun 25th, 13, 09:36 AM   #3 (permalink)
Vintage 68's Avatar
Thumbs up Re: 1993 3.4L running very poorly
Sorry I did not see this sooner (don't look through 3rd, 4th, 5th ... gen forums very often).
Cat systems on these early/mid-90's vehicles are at the end of their life-cycles and most likely plugged.
I recently went through this on a 90's Oldsmobile (try to find parts for these ) and was able to order the cat from Summit.
If you haven't found yours yet try them, prices are very good for MagnaFlow replacement units
1968 Convertible
Some trucks
Vintage 68 is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
» Recent Discussions
Recoating Headers
Yesterday 07:43 PM
Last post by flat tire
Yesterday 11:05 PM
2 Replies, 50 Views
69 DZ302/M22/4.56...
Feb 20th, 20 07:44 PM
by alnukem
Last post by Luwi67
Yesterday 10:05 PM
18 Replies, 408 Views
best off the shelf 4...
Yesterday 06:16 AM
by dads67z
Last post by ctcz28
Yesterday 09:11 PM
7 Replies, 178 Views
Blue convertible top
Feb 17th, 20 08:50 PM
Last post by R66
Yesterday 08:53 PM
4 Replies, 176 Views
69 Z28 vacuum line...
Yesterday 12:47 PM
Last post by ctcz28
Yesterday 08:18 PM
3 Replies, 78 Views
New member from down...
Yesterday 05:06 AM
Last post by RDW
Yesterday 08:05 PM
4 Replies, 78 Views
69 Resto Mod project
Nov 1st, 15 07:39 AM
Last post by frog7151
Yesterday 05:59 PM
120 Replies, 13,219 Views
Anybody using the GM...
Yesterday 02:52 PM
Yesterday 05:10 PM
4 Replies, 93 Views
1967 Upper Ball Joint...
Yesterday 04:22 PM
by bob15
Last post by bob15
Yesterday 04:22 PM
0 Replies, 55 Views
69 Front turn signal...
Yesterday 12:13 PM
by KevinW
Last post by ZLP955
Yesterday 04:19 PM
4 Replies, 83 Views
