1997 Camaro ABS INOP light turned on - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Jul 19th, 13, 07:42 AM   #1 (permalink)
I already googled for answers and took all the suggestions to clean the sensor and break lines and everything but the light stays on. I took it to autozone and aft hook inch up their scanner their employee said it does not throw any codes but I don't think she understood what I was asking for. I think she was looking for check engine light and not the ABS light. Anyways does anyone knows what needs to be replaced. Also does anyone knows if the 97 camaro rs 30th anniversary has the traction control or not. I have an sgs button for the ABS but everything the auto place ask if it has traction control or not I have no idea what to answer.
Thanks guys!m
Searchneverend is offline   Reply With Quote Quick reply to this message
Old Jul 19th, 13, 07:45 AM   #2 (permalink)
NHBandit's Avatar
Re: 1997 Camaro ABS INOP light turned on
Until you have it properly scanned for codes by someone who actually knows what they're doing (not some Auto Zone chick) you're chasing your tail. Sorry if that's not what you want to hear.
NHBandit is offline   Reply With Quote Quick reply to this message
Old Jul 23rd, 13, 10:33 PM   #3 (permalink)
So I got it scanned at the body shop and its the right(passenger side) ABS sensor that needs to be changed. Is it a hard job to do it yourself or pretty simple? I hate messing with brakes, makes me wonder if I put them back right. And I believe the sensor is behind the calipers so I will probably have to remove the drum.
Old Jul 24th, 13, 04:23 AM   #4 (permalink)
Check the electrical connector first, you may need to disconnect and reconnect ensuring the connectors make good contact.
Check to make sure the sensor wheel is under the sensor head.
Sensor should be fairly easy to replace without removing anything except for a lock bolt holding it in place.
Let us know what happens.
Doing a good job is like peeing in your dark pants you get a warm feeling, but nobody notices
Old Jul 24th, 13, 10:23 AM   #5 (permalink)
Traction Control System (TCS) and Anti-Slip Regulation (ASR) are 2 names for the same thing. TCS was used by Pontiac while Chevy called it ASR. It was an option on both Firebirds and Camaros. There could be as many as 3 switches above the radio depending on how many options the car came with. The on-off switch is located above the radio in the middle. The default position is ON but you can turn it off after starting the engine. It can also be disabled. No switch means no ASR.
67 Camaro: 454/TH400/4.10 12 bolt. Lots of options: PS/PDB/PW, tilt, tach, gauges and more. K-K + 797-Z...
"Politics is the art of looking for trouble, finding it whether it exists or not, diagnosing it incorrectly and applying the wrong remedy" - Sir Ernest Benn
PowerWindows is offline   Reply With Quote Quick reply to this message
Old Oct 25th, 14, 05:38 PM   #6 (permalink)
Is sgs a form of traction control I have a 1997 camaro rs 3.8l
edmack94 is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
» Recent Discussions
Recoating Headers
Yesterday 07:43 PM
Last post by flat tire
Yesterday 11:05 PM
2 Replies, 50 Views
69 DZ302/M22/4.56...
Feb 20th, 20 07:44 PM
by alnukem
Last post by Luwi67
Yesterday 10:05 PM
18 Replies, 408 Views
best off the shelf 4...
Yesterday 06:16 AM
by dads67z
Last post by ctcz28
Yesterday 09:11 PM
7 Replies, 177 Views
Blue convertible top
Feb 17th, 20 08:50 PM
Last post by R66
Yesterday 08:53 PM
4 Replies, 176 Views
69 Z28 vacuum line...
Yesterday 12:47 PM
Last post by ctcz28
Yesterday 08:18 PM
3 Replies, 78 Views
New member from down...
Yesterday 05:06 AM
Last post by RDW
Yesterday 08:05 PM
4 Replies, 78 Views
69 Resto Mod project
Nov 1st, 15 07:39 AM
Last post by frog7151
Yesterday 05:59 PM
120 Replies, 13,219 Views
Anybody using the GM...
Yesterday 02:52 PM
Yesterday 05:10 PM
4 Replies, 93 Views
1967 Upper Ball Joint...
Yesterday 04:22 PM
by bob15
Last post by bob15
Yesterday 04:22 PM
0 Replies, 55 Views
69 Front turn signal...
Yesterday 12:13 PM
by KevinW
Last post by ZLP955
Yesterday 04:19 PM
4 Replies, 83 Views
