1998 3.8 camaro door sagging - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Aug 19th, 13, 01:58 PM   #1 (permalink)
My 1998 camaro's driver door was sagging. I replaced it with another hinge from another car that was not camaro but was a chevy hinge bracket that looked almost identical. the spring was a little shorter. However it did bolt up fine and closed smoothley but the door did not shut. It sags WAY more than when the bad original camaro hinge was on their. But like i said still no creaking sound. The hinge i took off the other car was good because the other car shut perfectly like a charm. i saw that their was a spacer on the old door so i installed the hinge with the spacer.. still no luck. the door was not cracked either. i ended up buying a whole new door at a junk yard from a camaro and installed it on my car. the hinge was bad but it shuts a little but still sags. on the camaro it came off of (a 95) it opened and closed with no problem BUT did make an aweful popping sound. but no sagging. when i installed it on my camaro like i said it still does not align right. their was a spacer also on this door. when i installed the passenger door there was no problem at all. smooth as silk and shuts perfect. Why is this happening to me? how can i fix it? ALSO, the body has no cracks in it.
wwejj0926 is offline   Reply With Quote Quick reply to this message
Old Aug 20th, 13, 11:03 AM   #2 (permalink)
Re: 1998 3.8 camaro door sagging
anybody?
Old Aug 20th, 13, 06:15 PM   #3 (permalink)
Does the new door where the hinge bolts upon, look like the original door, same shape?
Maybe remove the door and round file the top holes toward the front to bring the door up.
Only after you check ensuring the hinge bushings and pins are not worn out on both top & bottom hinge.
Maybe the spacer should go against the door and bottom hinge to push up the door?
Picture(s)?
Doing a good job is like peeing in your dark pants you get a warm feeling, but nobody notices
Old Aug 23rd, 13, 09:21 AM   #4 (permalink)
Thank you so much Everett. But I got it now. I did not align the bolts onto the white part where the bolts were taken off. The part where it was aligned before. Now it's not sagging. I also got another hinge from the junk yard that interchanged. Thanks again. I love it when people help.
Old Aug 23rd, 13, 10:29 AM   #5 (permalink)
The white part?
Old Sep 3rd, 13, 07:07 PM   #6 (permalink)
The white part on the hinge where the bolts were. (The two circles where the paint came off)
Location
Location
First Name
» Recent Discussions
Here We Go :( - Need...
Feb 25th, 20 01:47 PM
Last post by r_w
Yesterday 09:31 PM
11 Replies, 236 Views
$750 for just pipe...
Feb 25th, 20 07:48 AM
by CHIPS
Last post by ctcz28
Yesterday 07:52 PM
13 Replies, 344 Views
Advice pls....
Yesterday 02:25 PM
Last post by slazisme
Yesterday 07:26 PM
1 Replies, 68 Views
Test-N-Tune, X half a...
Mar 15th, 15 01:26 PM
Last post by 01ssreda4
Yesterday 07:19 PM
134 Replies, 17,865 Views
Humpday Humor, 2/26 ......
Feb 25th, 20 03:58 PM
Last post by scblucam
Yesterday 07:08 PM
4 Replies, 146 Views
Noob here
Feb 23rd, 20 04:52 PM
by 19SS69
Last post by 19SS69
Yesterday 06:32 PM
4 Replies, 175 Views
1969 Interior Wood
Feb 24th, 20 02:02 PM
by 19SS69
Last post by 19SS69
Yesterday 06:25 PM
4 Replies, 113 Views
1967 Upper Ball Joint...
Feb 22nd, 20 04:22 PM
by bob15
Yesterday 05:58 PM
12 Replies, 345 Views
Hello
Yesterday 12:07 PM
Last post by Everett#2390
Yesterday 05:20 PM
1 Replies, 48 Views
New Member Intro
Yesterday 11:33 AM
Yesterday 05:18 PM
2 Replies, 62 Views
