1996 camaro cranks and then dies - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Sep 4th, 13, 02:29 PM   #1 (permalink)
Unhappy 1996 camaro cranks and then dies
My gf called me one day and told me the camaro wouldnt run. The next day i went to go look at it and the first thing i did was hop in it and try to start it. It was completely dead. The only that happened was that the BCM was making a clicking noise. The only time the clicking noise stopped was when the key was turned over. It would also get lighter when i messed with the headlights switch. I then run jumper cables to the car and i would get her to crank and she would run about 2 seconds and then shut off even with the jumper cables still hooked up. I cranked her a few times and everytime i got the same results. The only time i got her to run a little longer was when i was reving the engine but right after let off the gas she would shut off. The day before there was a loud noise coming from the rear of the car and i was told it was the fuel pump. The day this happened the noise wasnt as loud as the day before but it was still there. Aslo when i messed with the headlight switch the intensity of the noise would change for a second. The theories ive been told are: the fuel pump could have gone out.... It could be the alternator..... it could be the crank shaft sensor..... or it could be an electical problem. She is my first car and i payed for her myself so i have got very attached to her and i really want to get her fixed. I hope you guys can point me in the right direction.
LoneWolf420 is offline   Reply With Quote Quick reply to this message
Old Sep 4th, 13, 07:04 PM   #2 (permalink)
Re: 1996 camaro cranks and then dies
First, I would take the battery out and externally charge it for a couple days.
If a new type charger is used, set the charger on 10 AMPS let charge until the 'CHARGE' light comes on, then let the battery charge on 2 AMP setting for a 24 hour period.
Do not set the battery on concrete, place the battery on wood to isolate it from the floor.
The noise you may be hearing could be a bad bearing in the alt and fiddling with the headlamp switch would be placing a load on the alt thus the bearing noise. Or a slipping belt due to the heavy load, discharged battery and accessory power demanded.
The fuel pump should hum for 2-3 seconds when the ign key is turned to IGN as controlled by the PCM. Fuel pump relay may need swapping out as the contacts may be burnt.
Spark plugs may need removed and dried out if wet with fuel. With cold coolant, the PCM will go into 'choke mode' and fuel like no tomorrow. If engine does not keep running, plugs become wet with fuel and will not work. You may need to hold pedal to the floor to clear out a flood condition.
Getting a Haynes manual will help with the Camaro, Amazon.com, RockAuto.com, or your local parts store.
Welcome, Lone Wolf.
Doing a good job is like peeing in your dark pants … you get a warm feeling, but nobody notices
Old Sep 6th, 13, 09:11 AM   #3 (permalink)
Thank you. Another big thing that totally slipped my mind is that I had flushed the radiator out earlier and put new coolant in the radiator. Maybe this has something to do with the car dieing on me.
Old Sep 6th, 13, 09:33 AM   #4 (permalink)
Certainly can as the PCM coolant sensor is sensing air temp vice coolant temp.
Old Sep 6th, 13, 09:41 AM   #5 (permalink)
And that's where the spark plugs come into play?
Old Sep 7th, 13, 09:29 AM   #6 (permalink)
I have put a new alternator, new battery, new fuel filter, and I know the fuel is running all the way to the engine because I pushed the gas valve near the engine and fuel came squirting out but still no luck. She is doing the same thing.
Old Sep 18th, 13, 07:50 PM   #7 (permalink)
You would need to get fuel pressure gage and attach it to the spot on the fuel rail and see what you have as you try to start the car. You may have a bad fuel pump, as the car gos to start the pump might be giving out. If its the original pump and you have quite a few miles on here its probably time for the new pump.
frankzlt1 is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
» Recent Discussions
$750 for just pipe...
Yesterday 07:48 AM
by CHIPS
Last post by Mkelcy
Yesterday 11:43 PM
10 Replies, 221 Views
Rough running with...
Feb 23rd, 20 05:57 PM
Last post by Fred Mertz
Yesterday 10:21 PM
2 Replies, 93 Views
68 restoration take 2
Feb 23rd, 20 07:02 PM
Last post by yellow69RS
Yesterday 10:12 PM
3 Replies, 179 Views
'68 can I remove the oil...
Yesterday 09:30 PM
Last post by kookykrispy
Yesterday 09:30 PM
0 Replies, 45 Views
Here We Go :( - Need...
Yesterday 01:47 PM
Yesterday 09:25 PM
10 Replies, 163 Views
Batterey Voltage
Feb 24th, 20 06:51 PM
by Elwaupo
Last post by SOA-Nova
Yesterday 08:59 PM
13 Replies, 190 Views
67 parking light mod
Feb 21st, 16 07:06 AM
by jcdubs
Last post by Gary Dorion
Yesterday 08:15 PM
10 Replies, 922 Views
Repalacing turn signal...
Feb 24th, 20 07:36 PM
Last post by Larry Madsen
Yesterday 07:45 PM
7 Replies, 133 Views
Turn signal switch...
Feb 23rd, 20 09:07 PM
by Tims67
Last post by Tims67
Yesterday 07:26 PM
6 Replies, 141 Views
AAR radios
Jul 23rd, 19 09:19 AM
Yesterday 07:26 PM
17 Replies, 1,269 Views
