1998 camaro wont start - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Sep 10th, 13, 02:46 PM   #1 (permalink)
I bought a brand new battery. I turned my camaro on after the brake job to test drive it and it started. it seemed like it made kind of a funny sound when it started but it could just be in my head. anyways the speedometer started to fluctuate at idle and the RPM's remained the same. I noticed i had the head lights unplugged since i replaced the fender and bumper. so i turned the car off and plugged in the headlights. i started the car and now it wont start it just clicks. its a brand new battery and i tested the voltage and it was fine. i got the starter removed and test it and it fine. but im wondering if a fuse was blown because all the wires going through the grommet in doors is hooked to nothing. power window wires and the speaker. its because i changed the door and im gonna put my old manual window regulator in it. could it be that some of these wires that are hooked to nothing be touching metal and linked in with the head lights and blowing a fuse not causing it to start? if not what else could it be?
wwejj0926 is offline   Reply With Quote Quick reply to this message
Old Sep 10th, 13, 07:06 PM   #2 (permalink)
Re: 1998 camaro wont start
Turn on headlights.
Now start engine.
If lights dim and starter clicks, not enough power from battery - cables, needing wire brushed, or low charge on battery.
If lights don't dim, maybe another starter relay replacement.
Also, once alt is on, check charging voltage across battery posts, should be around 14.5 volts.
Could also have a drain of more than 0.1 amp when Camaro is off and draining battery.
If ign key has resistor chip, tumbler may not be reading the chip satisfying VATS allowing starter relay to energize.
Doing a good job is like peeing in your dark pants you get a warm feeling, but nobody notices
Old Sep 10th, 13, 09:39 PM   #3 (permalink)
Thank you for your info. I put the starter back on and it didnt start but jumped the car off from my truck and it works now. It just wasnt charged all the way when i bought this new battery
Location
Location
First Name
» Recent Discussions
Tim's 69 Grocery Getter
Dec 11th, 18 07:23 PM
Last post by Vega$69
Today 01:21 PM
199 Replies, 13,819 Views
350 Not running smooth
Jan 23rd, 20 12:58 PM
by Easy
Last post by dave ray
Today 01:20 PM
8 Replies, 305 Views
3D Printed Grommet
Today 05:37 AM
by r_w
Last post by blitzer454
Today 12:01 PM
1 Replies, 66 Views
Vintage air installation...
Apr 5th, 13 07:27 PM
Today 11:42 AM
13 Replies, 16,312 Views
muncie 4 speed and rear...
Today 05:12 AM
by dads67z
Last post by flat tire
Today 11:09 AM
9 Replies, 142 Views
PWM fuel pump
Feb 14th, 20 09:43 AM
Last post by CarlC
Today 10:56 AM
17 Replies, 282 Views
AC CV-7260 PCV Valve
Today 10:55 AM
Last post by Rick Goble
Today 10:55 AM
0 Replies, 33 Views
Are Any Old Members...
Jan 31st, 20 06:23 AM
Last post by atg67
Today 10:49 AM
78 Replies, 2,584 Views
Hi New member here just...
Today 06:53 AM
Last post by DougL
Today 10:28 AM
3 Replies, 67 Views
What's the thoughts on...
Yesterday 09:49 PM
by 406bull
Last post by bertfam
Today 09:56 AM
2 Replies, 132 Views
