3.8l stock z28 to 350 carbed? - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Dec 4th, 13, 08:25 PM   #1 (permalink)
i made the post some time ago but i need to know now my 3.8l oil pump blow on the enter state and i pushed it 1.3 miles home not fun at all as i was saying in my last post i have a carbed 350 i need this car i have all the tools to do the swap if it is as easy as dropping in a little motor work then done i need this car for work and school i can take sick days to swap it and i dont learn anything in school if seen it done with smallblocks with carbs and big block with carbs i dont have moneys for a other car right now please if any one and send me to a website or just tell me it wold be real nice thanks for reading
mobility is offline   Reply With Quote Quick reply to this message
Old Dec 5th, 13, 04:13 AM   #2 (permalink)
Re: 3.8l stock z28 to 350 carbed??
You might read here for mechanical fit, the nuts & bolts of the swapout.
http://camaroforums.com/forum/93-02-...-thread-68658/
For carbed, you will need ign voltage for the carbed ign.
First and foremost, check trans bellhousing bolt patterns on both trans to be used and engine going in.
Doing a good job is like peeing in your dark pants you get a warm feeling, but nobody notices
Old Dec 5th, 13, 11:16 AM   #3 (permalink)
Joe Harrison's Avatar
Buy a used 3.8 off craigs list....you will never swap to v-8 with no cash. The 3.8's are a dime dozen and don't look for Z/28 with a 3.8....they did not make them.
-Mark Donahue
My 67 Camaro Time Line
Joe Harrison is offline   Reply With Quote Quick reply to this message
Old Dec 5th, 13, 07:09 PM   #4 (permalink)
they did make base z28 camaros with the 3.8l look it up
Old Dec 5th, 13, 07:51 PM   #5 (permalink)
Never Happened
snakedr is offline   Reply With Quote Quick reply to this message
Old Dec 5th, 13, 07:54 PM   #6 (permalink)
Incorrect. The newest camaro's were rumored to have a base model in that configuration, but that is all it was, a rumor. Z28 has always referred to a performance package in one way or another, and there is no way that a 3.8 would fall into that category, unless the previously rumored 3.8 Twin Turbo was built which it wasnt. I would like to read the article you heard that from.
1967 RS/SS Camaro 383 5 speed tremec 3.70
1967 RS/SS Camaro 383 5 speed tremec 4.10
1967 RS Camaro Convertible 327 4 speed 3.73
1969 SS Camaro 6.0 LS Twin Turbo 5 Speed 3.50
2013 ZL1 Camaro roto-fab airbox pulley swap Rest In Pieces March 27 2014
FTF Automotive is offline   Reply With Quote Quick reply to this message
Old Dec 5th, 13, 08:07 PM   #7 (permalink)
DjD
DjD's Avatar
From '93 - '97 the base Camaro came with a 207ci V6 (L32). In '95 they added a 231ci V6 (L36) to the lineup and in '96 they dropped the L32 from the lineup. Then there was a Z28 during those years with a 350ci V8 (LT1). If you got a V6 is was not a Z28! In '98 - '02 the pattern stayed the same V6 (L36) base Camaro. V8 (LS1) Z28.
...Dennis
DjD is offline   Reply With Quote Quick reply to this message
Old Dec 5th, 13, 09:03 PM   #8 (permalink)
BonzoHansen's Avatar
1. all z28s were V8 cars.
2. you will have to cut the cowl up to get a carb in. and trying to get this done will end up costing you more money than a used engine or even perhaps a rebuilt one.
TC Member #13
BonzoHansen is offline   Reply With Quote Quick reply to this message
Old Dec 6th, 13, 12:35 AM   #9 (permalink)
Your on Team Camaro....no need to look it up. Your v-6 Camaro is not a Z/28.
-Mark Donahue
Old Dec 6th, 13, 04:47 AM   #10 (permalink)
Look at the RPO sticker for 'Z28'
No Z28, Camaro is not a Z28
As said, V6, not a Z28 optioned Camaro.
Old Jan 30th, 14, 09:49 PM   #11 (permalink)
Dropping an engine from a Gen IV car is not as easy as Gen I. They come out the bottom, not the top.
Carbed 350 won't fit without serious cut in cowl area and you will probably break the winshield in the process. You also don't have room for a standard distributer either - LT1's had this up front, LS does not have one.
Find a used 3.8 as recommended above and put it in from the bottom. Anything else is not worth the effort or cash - these cars aren't worth much at this time.
'69 Coupe
Original 350 PG, Now 427 4 speed
Owned since 1977
copo9560 is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
» Recent Discussions
Here We Go :( - Need...
Feb 25th, 20 01:47 PM
Last post by r_w
Yesterday 09:31 PM
11 Replies, 236 Views
$750 for just pipe...
Feb 25th, 20 07:48 AM
by CHIPS
Last post by ctcz28
Yesterday 07:52 PM
13 Replies, 344 Views
Advice pls....
Yesterday 02:25 PM
Last post by slazisme
Yesterday 07:26 PM
1 Replies, 68 Views
Test-N-Tune, X half a...
Mar 15th, 15 01:26 PM
Last post by 01ssreda4
Yesterday 07:19 PM
134 Replies, 17,865 Views
Humpday Humor, 2/26 ......
Feb 25th, 20 03:58 PM
Last post by scblucam
Yesterday 07:08 PM
4 Replies, 146 Views
Noob here
Feb 23rd, 20 04:52 PM
by 19SS69
Last post by 19SS69
Yesterday 06:32 PM
4 Replies, 174 Views
1969 Interior Wood
Feb 24th, 20 02:02 PM
by 19SS69
Last post by 19SS69
Yesterday 06:25 PM
4 Replies, 113 Views
1967 Upper Ball Joint...
Feb 22nd, 20 04:22 PM
by bob15
Yesterday 05:58 PM
12 Replies, 345 Views
Hello
Yesterday 12:07 PM
Last post by Everett#2390
Yesterday 05:20 PM
1 Replies, 48 Views
New Member Intro
Yesterday 11:33 AM
Yesterday 05:18 PM
2 Replies, 62 Views
