1995 z28 oil leak from dip stick? - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Mar 28th, 14, 04:38 AM   #1 (permalink)
Ok guys im a female looking for answers. I have a 1995 z28 it has just started leaking oil. Have changed the valve cover gaskets changed oil filter checked drain plug. Also checked the pcvthing and it sucks good. I noticed that my dip stick is loose and the top plastic piece is broke so it doesnt seal right, my ex told me that wouldnt matter because oil cant come up and out of the dip stick is that true?
calimama is offline   Reply With Quote Quick reply to this message
Old Apr 3rd, 14, 12:11 AM   #2 (permalink)
Re: 1995 z28 oil leak from dip stick?
Engines can leak oil from about everywhere. It can come out of the tube, but is unlikely as it would take a bunch of crankcase pressure that your engine is not going to develop. More than likely you have a timing cover leak at the front seal, or the pan gasket, or the rear main seal. Most likely places.
1967 RS/SS Camaro 383 5 speed tremec 3.70
1967 RS/SS Camaro 383 5 speed tremec 4.10
1967 RS Camaro Convertible 327 4 speed 3.73
1969 SS Camaro 6.0 LS Twin Turbo 5 Speed 3.50
2013 ZL1 Camaro roto-fab airbox pulley swap Rest In Pieces March 27 2014
FTF Automotive is offline   Reply With Quote Quick reply to this message
Old Apr 4th, 14, 02:56 PM   #3 (permalink)
If the rings are worn you could have a lot of blow-by. I've seen that actually blow out the dipstick in the worst cases. Blow-by isn't uncommon if your motor has high mileage, an improper rebuild, broken piston, broken rings etc. In any event, I'd replace the broken dipstick. If you're suspicious of blow-by, take the oil cap off and see if you can feel air puffing out of the hole.
dnult is offline   Reply With Quote Quick reply to this message
Tags
dipstick, oil leak
Location
Location
First Name
» Recent Discussions
3D Printed Grommet
Today 05:37 AM
by r_w
Last post by blitzer454
Today 12:01 PM
1 Replies, 66 Views
Vintage air installation...
Apr 5th, 13 07:27 PM
Last post by Vega$69
Today 11:42 AM
13 Replies, 16,312 Views
Tim's 69 Grocery Getter
Dec 11th, 18 07:23 PM
Last post by Shannon4570
Today 11:20 AM
198 Replies, 13,817 Views
muncie 4 speed and rear...
Today 05:12 AM
by dads67z
Last post by flat tire
Today 11:09 AM
9 Replies, 142 Views
PWM fuel pump
Feb 14th, 20 09:43 AM
Last post by CarlC
Today 10:56 AM
17 Replies, 282 Views
AC CV-7260 PCV Valve
Today 10:55 AM
Last post by Rick Goble
Today 10:55 AM
0 Replies, 33 Views
Are Any Old Members...
Jan 31st, 20 06:23 AM
Last post by atg67
Today 10:49 AM
78 Replies, 2,584 Views
Hi New member here just...
Today 06:53 AM
Last post by DougL
Today 10:28 AM
3 Replies, 66 Views
What's the thoughts on...
Yesterday 09:49 PM
by 406bull
Last post by bertfam
Today 09:56 AM
2 Replies, 132 Views
1968 Stock Horseshoe...
Today 08:10 AM
Last post by yellow69RS
Today 09:55 AM
1 Replies, 46 Views
