1996 Camaro 3.8 V6 fuel pressure problems - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Apr 7th, 14, 06:35 PM   #1 (permalink)
Send a message via MSN to csn69ss Send a message via Yahoo to csn69ss
I recently drove this car 1000 miles accross the Philippines, but on the way I encountered a strange problem related to the fuel pressure. Under hard acceleration up hill the car started sputtering and running real rough, pulling over to the side of the road it was idling real rough. This was the middle of nowhere, but since I had a spare new fuel filter in the trunk I decided to try and change the filter. Opening the connection on the old filter I noticed the fuel pressure was really high, i changed the filter and the car fired right up again. the old filter was very dirty.
I thought the problem was solve, however next steep uphill and hard acceleration the car started acting up exact same way again. Once again I just released the pressure at the fuel filter and the car fired right up again.
It seems this is fuel pressure related, does anyone has any idea?
btw. I made it the next 500 miles just being soft on the throttle
1969 L65/TH350
csn69ss is offline   Reply With Quote Quick reply to this message
Old Apr 7th, 14, 06:39 PM   #2 (permalink)
Re: 1996 Camaro 3.8 V6 fuel pressure problems
I forgot to mention that I just recently did replace the intank fuel pump with an original one. And it was clear from our journey that the fuel pressure fluctuates, as the pump noise goes from real quiet to whining noise and pump cutting in/out when the engine was running real rough (after the hard accelerations).
1969 L65/TH350
Old Apr 24th, 14, 10:28 PM   #3 (permalink)
I ordered a new fuel press regulator, but since this is in the Philippines it will take some time before I can get it installed, hopefully this will cure the issue.
1969 L65/TH350
Old Apr 25th, 14, 04:05 AM   #4 (permalink)
Could the steepness of the hill divert fuel to another part of the tank thereby starving the pump?
Only troubleshooting tip I have is duct tape a fuel pressure gauge to the windshield with the gauge hooked to the Scrader valve on the fuel rail and go climb a hill and see if the gauge drops off climbing or coming down from the hill.
Doing a good job is like peeing in your dark pants … you get a warm feeling, but nobody notices
Old May 8th, 14, 07:41 PM   #5 (permalink)
Problem not only on hills, during all heavy acceleration, empty tank, half full or full, no difference.
1969 L65/TH350
Old May 9th, 14, 04:34 AM   #6 (permalink)
Since it appears all the time, after warm-up, and the problem goes away after relieving the fuel line pressure,
I suggest the next time it happens, opening the filler cap and notice if the tank pressure is relieved by a large amount, If so, then I would look at the charcoal cannister solenoid(s) as they control and relieve the tank pressure by PCM commands.
The fuel pump groans, as you mention, are an indication of the pump working, quiet = no load, heavy noise = working.
Old Jun 5th, 14, 12:08 AM   #7 (permalink)
hi Everett, thanks, will check tank pressure as well.
I agree with you on the noise level of the pump, pressure goes so high the pump cuts out.
1969 L65/TH350
Old Dec 1st, 14, 10:25 PM   #8 (permalink)
Well I didn't help replacing the fuel pressure regulator, it still cuts out of high pressure but only if you step on it.
1969 L65/TH350
Old Dec 2nd, 14, 04:40 AM   #9 (permalink)
Is the return line restricted?
Location
Location
First Name
» Recent Discussions
$750 for just pipe...
Yesterday 07:48 AM
by CHIPS
Last post by Mkelcy
Yesterday 11:43 PM
10 Replies, 221 Views
Rough running with...
Feb 23rd, 20 05:57 PM
Last post by Fred Mertz
Yesterday 10:21 PM
2 Replies, 93 Views
68 restoration take 2
Feb 23rd, 20 07:02 PM
Last post by yellow69RS
Yesterday 10:12 PM
3 Replies, 179 Views
'68 can I remove the oil...
Yesterday 09:30 PM
Last post by kookykrispy
Yesterday 09:30 PM
0 Replies, 44 Views
Here We Go :( - Need...
Yesterday 01:47 PM
Yesterday 09:25 PM
10 Replies, 163 Views
Batterey Voltage
Feb 24th, 20 06:51 PM
by Elwaupo
Last post by SOA-Nova
Yesterday 08:59 PM
13 Replies, 190 Views
67 parking light mod
Feb 21st, 16 07:06 AM
by jcdubs
Last post by Gary Dorion
Yesterday 08:15 PM
10 Replies, 922 Views
Repalacing turn signal...
Feb 24th, 20 07:36 PM
Last post by Larry Madsen
Yesterday 07:45 PM
7 Replies, 133 Views
Turn signal switch...
Feb 23rd, 20 09:07 PM
by Tims67
Last post by Tims67
Yesterday 07:26 PM
6 Replies, 141 Views
AAR radios
Jul 23rd, 19 09:19 AM
Yesterday 07:26 PM
17 Replies, 1,268 Views
