02 Z28 Problem?!? - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Dec 24th, 14, 10:00 PM   #1 (permalink)
Angry 02 Z28 Problem?!?
Current problem... idles fine, starts fine. After about a mile down the road every time in every gear, it starts to lose all power... unless the accelerator pedal is completely to the floor i have no power.
I have replaced the fuel filter, all plugs & wires, oil change within the last 1k miles, replaced O2 sensors.
The car is not receiving fuel unless pedal is all the way down, any thoughts?
car has 100k on it
C.Phelps is offline   Reply With Quote Quick reply to this message
Old Dec 24th, 14, 10:05 PM   #2 (permalink)
Re: 02 Z28 Problem?!?
Maybe a plugged cat converter? I had a Buick Century a few years back that ran perfect with no codes until you tried to go up steep hills and had no power to do so, and that's what that needed, good luck!
Mostly Camaros and FINALLY a Double Nickel
Yellow69RSZ is offline   Reply With Quote Quick reply to this message
Old Dec 24th, 14, 10:11 PM   #3 (permalink)
I do not have cats on my car...
Old Dec 24th, 14, 10:13 PM   #4 (permalink)
is it showing any codes? is check engine light on?
realz69 is offline   Reply With Quote Quick reply to this message
Old Dec 24th, 14, 10:19 PM   #5 (permalink)
Check engine light has been on since i bought the car at 60k its on because it throws the same exhaust code for not having cats... before i replaced my O2 sensor it threw a code for that, then it threw a code for a random misfire, post tune up no new codes same problem
Old Dec 24th, 14, 11:07 PM   #6 (permalink)
jno
Is this a new problem? Was it running okay with the exhaust codes?
Maybe screen on fuel pump is clogged or pumps on its way out? I think you can check the fuel pressure somehow. (Just a guess on the pump)
jno is offline   Reply With Quote Quick reply to this message
Old Dec 25th, 14, 12:05 AM   #7 (permalink)
If it doesn't have cats, unless the rear 02 sensors were turned off, it will throw codes and mess with the fuel trim.
It sounds like idle air control which is always an issue on Ls motors. Does it have a cam or aftermarket parts?
I would go to someone who knows how to tune, and have them hook their lap too up to the computer and see what's going on in real time.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline   Reply With Quote Quick reply to this message
Old Dec 28th, 14, 12:16 AM   #8 (permalink)
Yeah, this is the first time i have ever had an issue with the car. It ran excellent before its current state; even with the exhaust code 0400.
It is a stock LS1.. no Cam, just after market exhaust (installed 2 years ago)
I have been to two different mechanics, i think i might take it to a chevy dealership
Old Dec 28th, 14, 11:51 AM   #9 (permalink)
69-Pace's Avatar
Did anything change such as the computer being without power for an extended period of time? If it was told at one point to ignore the cats and then dumped that program and had to relearn from baseline it would be an issue in my opinion.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
» Recent Discussions
350 Not running smooth
Jan 23rd, 20 12:58 PM
by Easy
Last post by dave ray
Today 01:20 PM
8 Replies, 304 Views
3D Printed Grommet
Today 05:37 AM
by r_w
Last post by blitzer454
Today 12:01 PM
1 Replies, 66 Views
Vintage air installation...
Apr 5th, 13 07:27 PM
Last post by Vega$69
Today 11:42 AM
13 Replies, 16,312 Views
Tim's 69 Grocery Getter
Dec 11th, 18 07:23 PM
Last post by Shannon4570
Today 11:20 AM
198 Replies, 13,817 Views
muncie 4 speed and rear...
Today 05:12 AM
by dads67z
Last post by flat tire
Today 11:09 AM
9 Replies, 142 Views
PWM fuel pump
Feb 14th, 20 09:43 AM
Last post by CarlC
Today 10:56 AM
17 Replies, 282 Views
AC CV-7260 PCV Valve
Today 10:55 AM
Last post by Rick Goble
Today 10:55 AM
0 Replies, 33 Views
Are Any Old Members...
Jan 31st, 20 06:23 AM
Last post by atg67
Today 10:49 AM
78 Replies, 2,584 Views
Hi New member here just...
Today 06:53 AM
Last post by DougL
Today 10:28 AM
3 Replies, 66 Views
What's the thoughts on...
Yesterday 09:49 PM
by 406bull
Last post by bertfam
Today 09:56 AM
2 Replies, 132 Views
