1998 camaro 3.8 4l60e to manual t5 swap - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Dec 27th, 15, 11:43 AM   #1 (permalink)
Hello I have almost gotten every thing I need to finish my 1998 3.8 camaro 4l60e to manual t5 swap. My only problem is the wiring harness. The manual tranny that I'm installing came from a 1997 3.8 camaro.
1.) First, there is some kind of lever that was coming from the tranny to the the steering wheel switch. Is there anything I need to modify in changing the auto to manual switch? or can I just remove the lever?
2.) Secondly, there is two extra wiring connectors mounted to the pedal assembly for the clutch pedal. Is there any way I could add the connectors into the auto? For example would I need to ground and run it through a fuse so that the pcm can read it without popping off a code?
3.) Finally, the whole wiring harness that comes from the pcm that goes into the transmission has different connectors. Is there any way I could cut some wires and splice the tranny connectors so that they will fit into the manual? And will the pcm read it correctly without popping off codes?
I bought the pcm from the manual 97 camaro so I will be changing that.
wwejj0926 is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
» Recent Discussions
$750 for just pipe...
Yesterday 07:48 AM
by CHIPS
Last post by Mkelcy
Yesterday 11:43 PM
10 Replies, 220 Views
Rough running with...
Feb 23rd, 20 05:57 PM
Last post by Fred Mertz
Yesterday 10:21 PM
2 Replies, 93 Views
68 restoration take 2
Feb 23rd, 20 07:02 PM
Last post by yellow69RS
Yesterday 10:12 PM
3 Replies, 178 Views
'68 can I remove the oil...
Yesterday 09:30 PM
Last post by kookykrispy
Yesterday 09:30 PM
0 Replies, 42 Views
Here We Go :( - Need...
Yesterday 01:47 PM
Yesterday 09:25 PM
10 Replies, 163 Views
Batterey Voltage
Feb 24th, 20 06:51 PM
by Elwaupo
Last post by SOA-Nova
Yesterday 08:59 PM
13 Replies, 189 Views
67 parking light mod
Feb 21st, 16 07:06 AM
by jcdubs
Last post by Gary Dorion
Yesterday 08:15 PM
10 Replies, 921 Views
Repalacing turn signal...
Feb 24th, 20 07:36 PM
Last post by Larry Madsen
Yesterday 07:45 PM
7 Replies, 132 Views
Turn signal switch...
Feb 23rd, 20 09:07 PM
by Tims67
Last post by Tims67
Yesterday 07:26 PM
6 Replies, 140 Views
AAR radios
Jul 23rd, 19 09:19 AM
Yesterday 07:26 PM
17 Replies, 1,267 Views
