96 z28 trouble when starting up. - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Jan 27th, 16, 10:52 AM   #1 (permalink)
Hello everyone. I am having some problems with me 96 z28. Only mod is muffler delete and c6 corvette rims. The battery is a new autozone battery duralast gold that i bought early this month. I recently had the waterpump replaced because it was leaking water. After about a week the car wouldnt srart so i took it to a mechanic who said there was gasoline in the oil which he said was because of a bad fuel injector. He replaced the bad fuel injector drained the oil, put new oil in and a new oil filter. Car started up but still had to crank a lil bit to start it. I had him replace the fuel pump because it was throwing a evap purge code (p1441 i think) which i was told was a bad fuel pump usually. After that the car started up a lot quicker then before. A week later i started to feel the car taking longer to crank. It actually sounds like the crank was getting weaker as u cranked it but still turned on. This morning when i went to crank it, it sounded like the crank got real weak to the point where i thought it wasnt going to turn. But keeping the key forward even as weak as it sounded it turned on. I thought for sure it wasnt going to start. Anyone know what this could be? Any ideas? I'm going to try to take it to the mechanics after work ifnit turns on, but wanted to see what you guys think. Just trying to get an idea what type of repair costs im in for.
Other problems i have been having with the car is that it revs on its own when parked or stopped at a light. It started doing this about 2 years ago when i had a mechanic change the optispark plugs and wires. It was fine before they changed the plugs and wires... I have replaced the iac, egr, and tps. I even had them smoke the lines to check for vacuum leaks and replaced all the bad hoses. Still same problem. I have to disconnect the iac at a low idle when the car is cold just to stop it from revving on its own all the time. So yes, i drive it with the iac always disconnected. I dont know what else could be causing the problem with the revving. When i disconnect the iac. The car idles normal. I have taken it to several mechanics in this area but they are unable to figure it out as well.
My main concern right now is the starting up problem. I need this car for work right now so if it doesnt start on me im screwed. Also the car was parked for about 2 years. Opti plugs and wires were done 2 years ago before i parked it. And yes it was having revving issues before i parked it for 2 years.
Any help or thoughts would be greatly appreciated! Thanks!
MartineZ28 is offline   Reply With Quote Quick reply to this message
Old Jan 28th, 16, 03:21 AM   #2 (permalink)
Re: 96 z28 trouble when starting up.
On start-up, you might turn the ign sw to RUN and leave it there for about 3-4 seconds, then crank engine over.
This procedure, as i have learned, primes the fuel system, for a quicker start.
It also is troubleshooting tip for a leaky check valve in the fuel pump or leaky injector.
One would have to use a fuel pressure gauge and record pressures at start, run, and a couple hours after shutdown. No or lower pressure at shut down, leak.
There is a procedure in setting base timing and base idle rpm.
These two should be done before any troubleshooting/repairs happen.
You might remove the IAC and clean out the orifice and surrounding area.
Then reset base idle correctly.
You might get a Haynes manual and read up. Better than nothing.
Location
Location
First Name
» Recent Discussions
Vinyl top trim
Aug 10th, 08 08:19 PM
by rogerh
Last post by Sabinoerc
Today 08:15 AM
29 Replies, 2,762 Views
How much will swapping...
Yesterday 09:23 PM
Last post by Farm Boy
Today 07:55 AM
4 Replies, 95 Views
The Hugger69 goes ZL-1!
Apr 15th, 16 07:00 AM
by Hgger69
Last post by Hgger69
Today 07:47 AM
220 Replies, 24,695 Views
Kind of cool day for me
Aug 19th, 19 07:50 AM
Last post by Just 1 More
Today 07:43 AM
20 Replies, 776 Views
Tail light lense...
Yesterday 06:16 PM
Last post by daven1256
Today 07:13 AM
5 Replies, 99 Views
And another question
Yesterday 04:10 AM
by ktrim
Last post by Triman8654
Today 06:20 AM
1 Replies, 100 Views
69 rustbucket rebirth
Jul 22nd, 13 11:38 AM
Last post by 350sshugger
Today 06:18 AM
1 Replies, 182,372 Views
Earl's Vapor Guard Hose...
Today 05:52 AM
Last post by dhutton
Today 06:15 AM
1 Replies, 37 Views
Shock from horn
Aug 22nd, 19 06:59 AM
Last post by boyd66k20
Today 05:28 AM
10 Replies, 222 Views
Looking for suitable...
Aug 21st, 19 08:05 PM
Last post by Brettallen59
Today 04:55 AM
5 Replies, 159 Views
