92' Corvette LT1 change over to AFR heads - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Oct 2nd, 19, 04:04 PM   #1 (permalink)
Hello!
I could buy AFR LT1 Eliminator heads with 180 cc intake 54 cc chamber for my LT1 engine. I already installed a GMPP hot cam kit, which I want to use with the new heads. The original valve covers are modified to fit the rockers. I still own a 52 mm thottle body.
Now there are some questions
Are the heads a good choice? A K&N air filter, hedman headers, Flowmaster mufflers are still installed.
Are there more parts needed?
Modifications to the chip of the ECM?
Thanks for any help in advance!!!
69`Camaro, 92`LT 1 / 94' BW-6 speed, shorty headers+Flowmaster, Vette wheels, Eibach/hotchkis springs, koni shocks, Nova rear, Corvette 13" front brake system
[all certified by German association for technical inspection with Oldtimer title]
Markus is offline   Reply With Quote Quick reply to this message
Old Oct 2nd, 19, 06:13 PM   #2 (permalink)
Lonnie P's Avatar
Re: 92' Corvette LT1 change over to AFR heads
The AFR heads are a good performance head. I've used many of them over the years. I'm not sure what your performance goal is but I've typically gone to larger heads. The factory LT4 heads were even larger 195cc heads. The AFR full competition 195's flow pretty well.
The cam is decent for a factory grind but not the best choice for serious performance. It does have good street manners though.
You will definitely need a good tune for best results.
Also while it is apart, I would recommend upgrading to the '95-97 timing cover, chain & upgraded optispark. Lots of issues with the earlier versions.
Lonnie P is offline   Reply With Quote Quick reply to this message
Old Oct 4th, 19, 02:46 PM   #3 (permalink)
Hello!
I had a call with AFR. They recommend the heads I could buy from another gearhead.
But they told me I had to use new pushrods. My understanding is that I could use the original ones, just like the modified valve covers ( modiefied because of the GMPP kit with rocker arms) and the headman shorty headers.
@ Lonnie P
Please tell me more about the installation. Thanks for any help!
Old Oct 4th, 19, 03:42 PM   #4 (permalink)
The 180s are plenty for your needs they will run better than the LT4 heads even though they were bigger.
You can use the LT1 intake with them. If you use the comp ports youll need an LT4 intake GM $$$ or Edelbrock.
It will pull super hard youll be surprised, those lobes will last a long time. That fast ramp stuff just makes noise and eats parts far as Im concerned.
cv67 is offline   Reply With Quote Quick reply to this message
Old Oct 5th, 19, 08:19 AM   #5 (permalink)
Lonnie P's Avatar
You need different push rods because the factory heads used self aligning rockers & the new heads have push rod guide plates that require hardened push rods.
You would use an aftermarket roller rocker designed for a Standard small block Chevy with large diameter valve springs. Some roller rockers are too wide to clear the factory center bolt valve cover bolts.
I've had good luck with the Crane rockers.
Old Oct 5th, 19, 09:11 AM   #6 (permalink)
Hello!
I 'm using roller rockers from the GMPP Hot Cam Kit. They fit the original valve covers with some modifications.
Will they fit the AFR heads?
I don't want invest in parts, which were included at the hot cam kit, because the kit is nearly new.
Old Oct 5th, 19, 05:09 PM   #7 (permalink)
Lonnie P's Avatar
It's been a while since I've seen a set, but I think those are self-aligning. Look for a washer on either side of the roller tip. If so, you are likely to need another set.
Location
Location
First Name
» Recent Discussions
Distributor spins freely...
Apr 2nd, 20 03:09 PM
Last post by Harris Roc Malouda
Today 02:14 AM
33 Replies, 613 Views
I'm Back!
Yesterday 12:54 PM
by Codi
Last post by buenymayor
Today 02:13 AM
3 Replies, 76 Views
69 Camaro Turbo EFI 250
Yesterday 08:26 PM
Last post by carid
Today 12:55 AM
2 Replies, 52 Views
Old Movies with Camaros
Yesterday 07:42 AM
Last post by hotrodbaker
Today 12:32 AM
9 Replies, 208 Views
Humpday Humor, 4/1 ......
Apr 1st, 20 03:53 AM
Last post by adjudimo
Yesterday 11:40 PM
11 Replies, 242 Views
On a lighter note...
Apr 2nd, 20 08:43 PM
by 69Z28
Yesterday 11:16 PM
5 Replies, 168 Views
'67 396
Yesterday 03:11 PM
Yesterday 11:01 PM
7 Replies, 147 Views
Niblet Changes his...
Mar 10th, 20 05:10 PM
by Niblet
Last post by Niblet
Yesterday 09:56 PM
16 Replies, 527 Views
A little brake and...
Yesterday 09:16 PM
Last post by bill3337
Yesterday 09:16 PM
0 Replies, 26 Views
upper control arm...
Yesterday 02:10 PM
Last post by allanjs
Yesterday 09:10 PM
4 Replies, 76 Views
