97 Z28 spark plug change - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Jun 12th, 05, 09:50 AM   #1 (permalink)
My wife has a 97 Z28 that now has 97,000 miles on it and I think it is time to change the plugs. I have worked on small block chevys all my life but this looks like it is going to be a real challenge.
Any tips for this process would be much appreciated.
Thanks in advance>
Smallblocksforever is offline   Reply With Quote Quick reply to this message
Old Jun 12th, 05, 10:44 AM   #2 (permalink)
Re: 97 Z28 spark plug change
first off, make sure you use a spark plug socket with the rubber bing inside so it grips the plug when you are taking it out. Second, if you are going to change the dis. cap, keep the original one on the car, until you replace the plugs, then transfer the wires over to the new one, that way you dont screw up ithe ignition. Maybe look up the firing order for the engine, and the dis cap, so you can double check everything after. Another thing, it wouldnt be a bad idea to have a few ratchet extensions laying around, cuz you never know when youll need them. A telescopic mirror also works, to see around those tight corners. Last off, when you just cant seem to get at a certain plug, try from underneath the car, or the bottom if you have a lift.
Happy pllug replacing!!
1PimpinZ28 is offline   Reply With Quote Quick reply to this message
Old Jun 12th, 05, 10:48 AM   #3 (permalink)
ooops almost forgot. Does the car have a auto tranny??? When you finish up the plug replacing, start the motor, and put your hand on the valve covers, if a misfire occurs you will feel a noticable jerk in the motor. If you have a automatic tranny, put the car in drive with your foot on the brake, and apply a little bit of gas for a few seconds. This helps to load everything up. Once again....
Happy Plug replacing
Old Jun 12th, 05, 10:58 AM   #4 (permalink)
dont use bosh plugs,use ac delco what came out of it, i dont think u want to change the dis cap you have to take the water pump off to do so, this is a very hard plug change its best if you have a rack. some of the plugs are easyer from under the car. have fun!!!
67CAMAROSS is offline   Reply With Quote Quick reply to this message
Old Jun 12th, 05, 11:18 AM   #5 (permalink)
Just to let you know how bad it will be, I was told GM flat rate is 8 hrs to replace plugs on a 4th gen Z/28. Thank god it takes less than a hour for me to change them on my '01 V6.
Musclerodz is offline   Reply With Quote Quick reply to this message
Old Jun 12th, 05, 02:49 PM   #6 (permalink)
at my shop the laber book says 4.0 hrs, the wires are worse then the plugs
Old Jun 12th, 05, 08:51 PM   #7 (permalink)
Thanks for all the help, look's like the lift will be in order.
Thanks again
Old Jun 12th, 05, 09:06 PM   #8 (permalink)
67SS , can you tell me why not to use Bosch plug? I made a change last year on a 2000 Ls1 TA and replaced with Msd wires and standard single electrode tip Bosch... Something I should look out for? These were the plated body plugs,, I applied a anti sieze on the threads...
TC # 349
zdld17 is offline   Reply With Quote Quick reply to this message
Old Jun 13th, 05, 08:23 PM   #9 (permalink)
i have alot of people come into the shop that did there own tune up ran good before tune up but now they run bad . they just foul out quick ( bosh platinum and platinum 4) there ok if the car came with them like alot of euro cars but on an american and jap. cars ,there not so good.there is no plug that will give you more horsepower . i have friends that have $300,000. drag cars and use stock plugs.
Old Jun 13th, 05, 10:34 PM   #10 (permalink)
BlackCamaros's Avatar
Good news/bad news: They're not too bad to change. . . from under the car. Only one of the plugs was easy to reach from the top, all the others I did from under the car. Good luck.
'69 Camaro/M-21/4.11 . . . rotissery queen
BlackCamaros is offline   Reply With Quote Quick reply to this message
Old Jun 15th, 05, 05:07 PM   #11 (permalink)
Did 6 from top and two from under on 2000 WS6
TC # 349
Old Jun 15th, 05, 07:27 PM   #12 (permalink)
The Cars With The Ls1 I Can Do All From The Top,VERY EASY JUST TAKE THE A.I.R PIPES OFF
Location
Location
First Name
What Spark plug with HEI? 69Red Engine 3 Mar 12th, 05 01:07 PM
SBC Spark Plug Suffix Question. FBODY Electrical & Wiring 1 Sep 7th, 04 02:48 PM
Spark Plug Wire Length Scott Reeves HSV Electrical & Wiring 3 Oct 7th, 03 01:14 PM
Stripped spark plug hole, help. (cavalier) MarkM Engine 9 Jan 22nd, 03 02:47 PM
spark plug blow by?? maross396 Troubleshooting 3 Feb 15th, 01 08:41 PM
» Recent Discussions
The Hugger69 goes ZL-1!
Apr 15th, 16 07:00 AM
by Hgger69
Last post by bradss396
Today 05:48 PM
236 Replies, 26,731 Views
awaiting spring
Today 04:00 AM
Last post by cv67
Today 04:45 PM
10 Replies, 121 Views
Mirrors, Screws, D & R...
Oct 12th, 19 05:00 PM
by blm
Last post by blm
Today 04:38 PM
23 Replies, 810 Views
Issue With Front...
Today 04:18 AM
Last post by Brettallen59
Today 04:28 PM
23 Replies, 250 Views
Quiet High Performance...
Oct 18th, 19 07:18 PM
Last post by ss27
Today 04:16 PM
5 Replies, 175 Views
Adapter part # ?
Yesterday 02:33 PM
by 3d cad
Last post by dhutton
Today 04:12 PM
5 Replies, 136 Views
1 owner 67 rs 4 spd So...
Yesterday 04:57 PM
by cv67
Last post by Garfields Maro
Today 03:31 PM
7 Replies, 164 Views
Baffling suspension issue
Oct 7th, 19 04:39 PM
by Joe G
Last post by Joe G
Today 03:26 PM
32 Replies, 1,063 Views
69 Wilwood Frt Disc...
Oct 15th, 19 01:52 PM
Last post by eville
Today 03:15 PM
11 Replies, 239 Views
Well, I feel better...
Today 09:18 AM
by KevinW
Last post by ckaram
Today 02:07 PM
1 Replies, 75 Views
