Painting door jams - Team Camaro Tech
New Member Introductions New here? Please introduce yourself.
post #1 of 5 (permalink) Old Sep 21st, 07, 09:31 PM Thread Starter
Painting door jams
Hey everybody, this sight is great. I decided to paint my own car. I removed the doors (they needed new bushings) and then painted the jams. They look great. But being the amateur that I am, I got paint and clear on the outside. How do I get that off before I paint the rest of the car? Do I sand to remove it all? Or do I fine sand it? Thanks.
jmacdathird is offline
post #2 of 5 (permalink) Old Sep 22nd, 07, 05:33 AM
Mike B
mb302rs's Avatar
Re: Painting door jams
You did'nt say what paint system you are using, but most of the time you can prep the same as the rest of the outside of the car. Sand and blend so there is no roughness.
then prime -seal or whatever. Good Luck
p.s. If you post these questions in the body shop section of this forum you will get a faster response from guys who have alot of experiance.
Mike B
69 RS Z28 X33
69 SS (badged) X11
68 Jane in pieces
68 RS/SS BB major project
69 firebird 400 project (Currently under construction ) Pics below
Still wingless.
mb302rs is offline
post #3 of 5 (permalink) Old Sep 22nd, 07, 08:39 AM
If the outside of the car is clear coat then just lightly wet sand the color overspray that is on top of the existing clear with 2000 wet and then buff. It should be fine. If it is not bb/cc then you have problems.
68 convertible 327 Ralley Green, White top, Deluxe Ivory interior, powerglide with white bumblebee stripe
bdzee is offline
post #4 of 5 (permalink) Old Sep 22nd, 07, 10:31 PM
just sand it down if you have all ready prep the outside for paint then just hit with some 600 or finer but don't busted the clear. busting the clear could cause it to wrinkle when you apply the base to the outside .
89 rs convertible is offline
post #5 of 5 (permalink) Old Sep 22nd, 07, 10:35 PM
also if you haven't preped the outside of the car and it has the factory paint and not a repaint then you can use thinner .careful not to get thinner on your jambs or your hard work had gone to__________.
