1967 Camaro 12 bolt posi - Team Camaro Tech
New Member Introductions New here? Please introduce yourself.
post #1 of 3 (permalink) Old Jan 15th, 08, 08:19 PM Thread Starter
Hi I am new here and am wondering if anyone can help me identify and estimate a value for a rear end that I own. It is a 12 bolt posi with 4.10 gears. The housing casting number is 3894860. The ring gear has this number 3862526 10 41 12 66. the axle tube has a letter missing. what I can read is A 0221G2. It measures 54.5" from backing plate to backing plate. It has 10" drum brakes. From what I have researched I believe that the missing letter on the tube could b a Q. It now has non stock spring perches on it. There is evidence of it once having a radius rod bracket welded to it.It looks like an Eaton posi to me based on some pictures that i have seen of them. I believe it is possibly from '67 camaro probably with a 4 speed. Can anyone shed any light on a value and a certain identification? Any help is appreciated.
Thanks, Jeff
67jeff67 is offline
post #2 of 3 (permalink) Old Jan 16th, 08, 03:04 PM
Dave C
Re: 1967 Camaro 12 bolt posi
Welcome Jeff, You may want to move your question to Tech or put it in the classified.Good luck
PRO.ST69orange
post #3 of 3 (permalink) Old Jan 16th, 08, 08:38 PM Thread Starter
OK thank you I will do that.
67jeff67 is offline
