engine numbers - Team Camaro Tech
New Member Introductions New here? Please introduce yourself.
post #1 of 9 (permalink) Old Aug 4th, 09, 03:41 PM Thread Starter
engine numbers
I have a 67 camaro. I'm trying to see engine block numbers without removing tranny bracket. It's supposed to be a 327 with a power glide.
linn is offline
post #2 of 9 (permalink) Old Aug 5th, 09, 09:49 PM
JAY
Re: engine numbers
there is a great book
"chevy by the numbers"
that help you id almost everything gm
built from 1965 to 1969
but those numbers on the back of the block is
best way, you also can id heads by pulling valve cover
and of course crank also
you can have a block that says 350 but
is running 327 crank
good luck jay
JAYARTER is offline
post #3 of 9 (permalink) Old Aug 6th, 09, 01:09 AM
Re: engine numbers
Get the numbers off the engine and transmssion here :http://www.camaros.org/drivetrain.shtml and post them. Then we can tell you exactly what you have.
buenymayor is offline
post #4 of 9 (permalink) Old Aug 6th, 09, 05:15 AM
Jerry
Re: engine numbers
This could help:
http://www.mortec.com/
good luck
Jerry
67 RS coupe, Black
68 Pro street Torch Red, blown 427
rat3j396 is offline
post #5 of 9 (permalink) Old Aug 14th, 09, 05:58 PM
Jerry R.
jr68's Avatar
Re: engine numbers
welcome to welcome wagon
my Magnaflow X-pipe system sound clip, click the link
jr68 is offline
post #6 of 9 (permalink) Old Aug 14th, 09, 07:37 PM
Re: engine numbers
You have the exact same problem I have, the casting numbers on the back of the block (drivers side) at the back bottom of the head are hidden by -what I think it is- the powerglide's kickdown cable bracket, the space in there is so tight that you can not see more than the GM mark (frustrating) the only thing you have left is the engine assembly date and suffix code stamped on the front pad infront of the drivers side head. Mine is TI0I3MM: T=Tonawanda plant I0=October I3= 13th day of the month and MM stands for 327/275 hp (L30) with Powerglide transmission. On the cowl tag I have 10=October and D=4th week, so far so good. Other than that I took the head casting numbers which are 3890462, and all I could find about them is that they are double hump heads used in 327 and 350 engines between '64 and '67 and they could be either 2.02/1.60 or 1.94/1.50 64cc, I guess I won't know that either untill I take engine appart.
Luckily I am pulling the engine and transmission for a complete overhaul in the next couple of weeks, but after loosing a pound or two between swet and skin of my hands and knuckles that is as far as I got with the numbers.
Here is where I found out about my heads: http://www.thedirtforum.com/castings.htm
and here is the info on the assembly plant/date/suffix:
http://www.chevy-camaro.com/chevy-ca...oding-help.asp
http://www.camaros.org/drivetrain.shtml#PadStamps
According to the last one in 1967 there were 2 types of L30's MM=automatic and MK=3 or 4 speed manual
To all of you knowledgeable people reading these posts please correct me if I am wrong, because so far this is the only thing (aside from my hope) that my engine is matching to my car taht is until I pull it out anyway.
'67 RS is offline
post #7 of 9 (permalink) Old Aug 14th, 09, 07:38 PM
Re: engine numbers
BTW welcome!!!
'67 RS is offline
post #8 of 9 (permalink) Old Sep 2nd, 09, 05:25 PM
knightmoose's Avatar
Re: engine numbers
has to be on the drivers dive way in the back little to no room at all to see anything, cant see from under neath or the the top at all nothing...lying down accross the top oif the engine looking down I see the big GM letters 3970010 i think i have no idea if this makes since there is so much caked on oil, i may get some degreser tommorw and see what happens if it helps.
it about helping others
knightmoose is offline
post #9 of 9 (permalink) Old Sep 2nd, 09, 07:00 PM
Re: engine numbers
based upon Rats3j396 the engine block SM 3970010 is dated 1969
3970010....302.....69....4...Z-28 Camaro
3970010....327.....69....2...Trucks and industrial
3970010....350...69-80...2 or 4
im certain its a 327 probally a truck lol. Another eason why im switching outto the 383 ..
