Aloha from Maui 1988 IROC 305 TPI problems - Team Camaro Tech
New Member Introductions New here? Please introduce yourself.
post #1 of 1 (permalink) Old Jan 14th, 10, 09:17 PM Thread Starter
Aloha to all.
I'm new to this site, just found it while searching for answers.
Starting problems. Started out as a problem once in a while. Now it's all the time. Installed new plugs and wires, dist cap and rotor, coil, TPS, fuel filter, fuel pump relay. Still the same problem. It will start one time and run great. Shut it off and try to start again and it just turns over. When it does start and I let it run at idle it sometimes creeps up idle speed. I can hear the fuel pump come on when I turn the ignition on, but not everytime. Do I have a fuel delivery problem or maybe the ECM???
I also had the ignition module tested at NAPA and they said it was good so its still in there. HELP PLEASE!! Aloha, Chris
clayman is offline
