First Camaro!!! - Team Camaro Tech
New Member Introductions New here? Please introduce yourself.
post #1 of 13 (permalink) Old Nov 16th, 10, 08:47 PM Thread Starter
nate
First Camaro!!!
Been lurking on this site for sometime and finnaly pulled the trigger! 1967 Camaro in need of TLC, I drove it home 6.5hrs today!! This is my first Camaro and will be in need of advice many times over. I noticed I will need to address a couple of things soon.
On the freeway the temp. would stay @ 185', but during stops temp would climb to 210 and I would shut it down. Their is no fan shroud and has a clutch fan. I have a new OER shroud I got from owner, but fan is too big for shroud. I was thinking the hot air was not directed at clutch without shroud to get it hot enough to engage? Should I have a clutch fan on this car? It has a newer OER radiator, but the tranny cooler weld is leaking (very small) on top. I think I should buy used parts until I figure out exactly what direction Iím going to go. Ill post the best picture I have of motor and would appreciate any other insight that you see. Thanks for your help and Team Camaro! Nate
jazz2069 is offline
post #2 of 13 (permalink) Old Nov 16th, 10, 09:05 PM
Sean
Re: First Camaro!!!
Hell ya!!! that must have been one hell of a trip, minus the overheating....I would love to drive mine that far even if I had to stop a few times.....My suggestions would be to get a flex fan for much more air production that along with the shroud might do it....
WELCOME TO THE SITE.....and thats a mighty fine ride you got there...whats the engine specs?
irish420 is offline
post #3 of 13 (permalink) Old Nov 16th, 10, 09:08 PM
Re: First Camaro!!!
By all means keep the clutch part of the fan (if it is operating properly). You may want to change the fan blades out for factory one, then put the shroud on it. I'll bet that will cure the your problem. If the car has antifreeze in it and a good radiator cap, I wouldn't worry about 210 degrees, she ain't hot, yet.
buenymayor is offline
post #4 of 13 (permalink) Old Nov 16th, 10, 09:31 PM Thread Starter
nate
Re: First Camaro!!!
It has a 350 with Turbo 350, not a high out-put motor feels like around 240 or so, but is fun and sounds good.. has 10 bolt was a I-6 motor says owner, I havent ran the #'s yet.
jazz2069 is offline
post #5 of 13 (permalink) Old Nov 16th, 10, 11:20 PM
Larry
larryh56's Avatar
Re: First Camaro!!!
Welcome to TC! Yep a properly operating clutch fan should work great but you need the correct fan blade to work with your shroud. The accessory brackets and pulleys have been all changed but it depends on what you want as far as originality. I would recommend you install a PCV valve in the driver side valve cover and run that to the carb and keep the breathers on the pass. side or run a hose to the air cleaner base. There are a number of posts about that if you would like additional reading.
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #6 of 13 (permalink) Old Nov 17th, 10, 12:01 AM
Harley
wiskeesour's Avatar
Re: First Camaro!!!
I think you need a new OEM fan. I see your fan has some bent blades, that is not helping at all. Then get a shroud and make sure the colling system is in the best shape you can get it in. Not having a flex fan for awhile wont hurt you. Ive had cars with shrouds that were flex fans and oem clutch type both work really good for a daily driving stock or mild build small blocks.
Do some pressure washing under the hood, shoot a few cans of your choice color paint to spruce it up and correct problems as they arise! Drive the heck out of it for awhile THEN decide what route you want to take. I cant tell you how many guys on here would start heading one way then see something at a car show and start all over in another direction....
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #7 of 13 (permalink) Old Nov 17th, 10, 12:31 AM Thread Starter
nate
Re: First Camaro!!!
Is this what I need, will my clutch bolt to this fan? Thanks Nate
http://www.jegs.com/i/Derale/259/19118/10002/-1
jazz2069 is offline
post #8 of 13 (permalink) Old Nov 17th, 10, 02:37 AM
Re: First Camaro!!!
You won't find alot of love here for those flex fans. Get a GM fan that fits the shroud, put the shroud on, and I doubt you'll have anymore problems provided the radiator is good. You've got the '69 and later pulley/bracket setup on your car, so you may need a shroud for a 69, not sure.
post #9 of 13 (permalink) Old Nov 17th, 10, 03:10 AM
BILL
SPARKY69's Avatar
Re: First Camaro!!!
welcome to team camaro..front bumpers direct airflow properly..hahaha..nice ride..
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #10 of 13 (permalink) Old Nov 17th, 10, 03:37 AM
Re: First Camaro!!!
Welcome to the Club, Nate. Nice ride indeed and congrats on a trouble free journey home.
You might check the block/deck code under the alternator to check where the engine originated from.
I suspect maybe a late model, mid '80's Monte Carlo, or at least the accessory drive, as it has a smaller sheave on the w/pump pulley for a air pump and the 'tilt' of the fan blades. My '88 MCSS has the same set-up, pulleys and fan blade shape - nothing wrong with it, makes for a quiet fan. You will find older 4.1 & 4.5 Cadillac engines had the same style of fan blade.
post #11 of 13 (permalink) Old Nov 17th, 10, 06:37 AM
Jeremie
Re: First Camaro!!!
Congrats on the new Mustang eater, I mean camaro. everyone here is awsome at helping.
MTN10 is offline
post #12 of 13 (permalink) Old Nov 18th, 10, 10:33 AM
Guess
HwyStarJoe's Avatar
Re: First Camaro!!!
Nice first Camaro Nate!
As far as the temps go, it'll help to get the heater hoses off of the passenger side header too!
Run them up higher and clamp them along the wheel tub.
HwyStarJoe is offline
post #13 of 13 (permalink) Old Nov 18th, 10, 12:03 PM
Paul
Thumbs up Re: First Camaro!!!
Welcome to team camaro!!
1969 RS/SS DROPTOP is offline
