Rich 85 tpi - Team Camaro Tech
New Member Introductions New here? Please introduce yourself.
post #1 of 2 (permalink) Old Nov 24th, 10, 05:43 AM Thread Starter
Delbert
Rich 85 tpi
Hey camaro fans: I have a problem with a gas smell at idle,stalling on start up and chugging at 40 mph.other than that it runs fine Ha Ha .Its a 85 iroc the 305 has been replaced with a 350 all gaskets are new from the heads up. its holding steady vaccum at18. I have TPS volts set at .55 volts does anyone have any ideas. scratching my head in Galveston
Delbert Garrett is offline
post #2 of 2 (permalink) Old Nov 24th, 10, 08:26 AM
Jason
Re: Rich 85 tpi
did you mess with any of the TPI or just remove it and set it to the side? I would check your Fuel pressure regulator, make SURE you arent leaking fuel from somewhere, an injector, cold start injector, etc.
1967 Camaro Yenko Pro Touring Tribute (being built)
Follow my build
67YenkoJC is offline
