cutting tunnel for 5-speed? - Team Camaro Tech
New Member Introductions New here? Please introduce yourself.
post #1 of 8 (permalink) Old Dec 18th, 10, 11:13 AM Thread Starter
Stacy
Hi everyone. My name is Stacy and I am addicted to Camaros. Current project is swapping out the factory auto to a TKO 600 in my 69'. Got to the point where I have to cut the tunnel. Any advice would be greatly appreciated. I am picking up a 4" hole saw that I read is needed but is there a stincel available? I will not be using a console. Also, apologies if I have posted in the wrong place. Thanks.
rippenmad29 is offline
post #2 of 8 (permalink) Old Dec 18th, 10, 12:36 PM
Skip
Skeeter55's Avatar
Re: cutting tunnel for 5-speed?
Welcome to Team Camaro.... Heres a great link to help you threw the process.
https://www.camaros.net/forums/showth...tting+hole+TKO
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 8 (permalink) Old Dec 18th, 10, 04:16 PM
Jerry R.
jr68's Avatar
Saw your profile pic and had to ask . . . . what kind of beer you got there ?
my Magnaflow X-pipe system sound clip, click the link
jr68 is offline
post #4 of 8 (permalink) Old Dec 18th, 10, 05:49 PM
Andrew
Andrew69's Avatar
Welcome to T/C Stacy. What part of NC are you from?
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #5 of 8 (permalink) Old Dec 18th, 10, 08:58 PM Thread Starter
Stacy
In Winston Salem.
post #6 of 8 (permalink) Old Dec 18th, 10, 09:16 PM Thread Starter
Stacy
The number one beer in the world........Bud Light
post #7 of 8 (permalink) Old Dec 22nd, 10, 06:30 PM
topher
69 383 tko 5sp's Avatar
Wecome Stacey to TC. I just cut the tunnel on my 69 for the TKO 600. Used a 1 1/8" hole saw for each corner and finished it off from hole to hole with a cut off wheel. Worked well. I used the shift boot trim ring for the template. Using the stock boot, the lower flap of the boot should slip under the tunnel opening. Grind to fit. Hopes this helps.
69 383 tko 5sp is offline
post #8 of 8 (permalink) Old Dec 23rd, 10, 07:45 PM Thread Starter
Stacy
Definately helps. How did you decide exactly where to make the holes before cutting the opening? I returned the 4" hole saw after reading some more posts and what you did is what I believe is a better way of doing it I just am not sure exactly where or how big...Thanks for your help.
69' DSE front suspension, DSE subframe bushings, 13" Baers, Tree-fitty, TKO 600, Hooker Darkside headers, and is the object of my addiction.
