hello everyone :) - Team Camaro Tech
New Member Introductions New here? Please introduce yourself.
post #1 of 4 (permalink) Old Feb 14th, 11, 01:19 PM Thread Starter
adrian
hello everyone :)
i am new to this site, and was wondering when i have a question about a part or a ? on how to install a part where can i go to ask this question? lol maybe i can ask it here. i have a 1984 chevy c10 it has a sb in it and my modifications are magnum 280h cam from comp cams, rpm air gap intake, headers, turbo 400 with tci breakaway converter, 3.73 gears with posi. my question is what carb is great with this setup, is this a good setup, and do i have everything to make this cam work properly. its my first build so im excited and have many ? lol i believe everything else is stock could someone tell me how much compression im pushing and how much horsepower
bver20 is offline
post #2 of 4 (permalink) Old Feb 14th, 11, 05:22 PM
Re: hello everyone :)
You would get better and more responses by posting in the appropriate category related to the particular system of the vehicle. These questions you ask here would be best in Engine section.
Also, if you're wanting to know static compression ratio, readers need to know piston used - flat top with valve reliefs, 2 or 4 each, dished piston, how much volume in dish, bore size, head gasket used, as in thickness, cylinder heads used, as in combustion chamber volume, stroke used and lastly, if known, how far the piston is sunk into the block, whether the block has been decked or not - can you read the engine code numbers on the front of the pass side deck. If you can, generally it is a sign the block has not been decked, piston would be 0.025" below the deck, original design.
Granted, alot of the info mentioned above may be a little deep, but generalizations can be given, industry standards, so to speak, to get a 'close' static compression ratio.
We would more than happy to answer your questions, but more info given, the better answer given in return.
post #3 of 4 (permalink) Old Feb 15th, 11, 03:43 AM
BILL
SPARKY69's Avatar
welcome to team camaro!
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #4 of 4 (permalink) Old Feb 15th, 11, 05:18 PM
Paul
Thumbs up Re: hello everyone :)
Welcome to team camaro!!
1969 RS/SS DROPTOP is offline
