motor wont start - Team Camaro Tech
New Member Introductions New here? Please introduce yourself.
post #1 of 13 (permalink) Old Feb 15th, 11, 06:40 PM Thread Starter
darrell
motor wont start
hey guys-i am new here but i need yalls help-i found a 97 camaro at a swap meet for a 1000.00--it had the motor tore apart with bad rod bearings-after getting it home and research, i found out it was a true 97 30th aniv. Z4C, anyway i got a 96 camaro LT1 motor, put the 97 reluctor ring and timing cover on-installed new dist. new exhaust , all new O2 sensors new coil and plugs--installed the motor and cant get it to run-it tries to start but wont-the vats seem to be working(light goes off in run position and cranking) 43 lbs of fuel pressure--spark test at plugs show fire --tried another PCM -only not replaced is crank sensor and ignition module no codes please help acts like its late on timing
97Z4C is offline
post #2 of 13 (permalink) Old Feb 15th, 11, 07:51 PM
Ryan
Re: motor wont start
this may be a dumb question but are you sure the dizzy isnt 180 out.
Bowtie67
1967 Coupe
1973 RS/SS
2011 SS
bowtie67 is offline
post #3 of 13 (permalink) Old Feb 15th, 11, 08:26 PM Thread Starter
darrell
yep= it goes in one way but could be forced in wrong--i took the dang thing down today to just make sure -put on tdc and pulled cap and 2 checked dist
97Z4C is offline
post #4 of 13 (permalink) Old Feb 15th, 11, 08:39 PM
Jerry R.
jr68's Avatar
Welcome to welcome wagon
my Magnaflow X-pipe system sound clip, click the link
jr68 is offline
post #5 of 13 (permalink) Old Feb 15th, 11, 08:52 PM
Steiner
An LT1 will run without the crankshaft sensor as it is used primarily for misfire detection. It uses the OptiCrap for ignition functions. Keep in mind that if you're using the balancer indicator for TDC that it shows TDC twice.....might want to pull plug 1 and put your thumb over the hole while you pull the engine over so you know you're on TDC for 1 and not 6.
Another thing to verify is the wires. The LT1 cap is set up so the plugs go to each side neatly but the order does not match cylinder order. I almost always put a couple on swapped on my S10 which uses a similar cap.
'69 Camaro
500hp/538lbft
Steiner is offline
post #6 of 13 (permalink) Old Feb 15th, 11, 09:20 PM Thread Starter
darrell
thanks for all the input--i did check tdc by finger on #1 hole and then put a small srewdriver in and rolled crank back and forth till piston at tdc as for as wires man i tripled checked them---i did notice that adapter plug that plugs into dist. , the red and black wire was recessed into plug and might not have been touching well r not at all (i think its #D if not mistaken) no i did not try to plug it in backwards--only thing left i know is ignition module (gonna put new harness and module on tommorow
97Z4C is offline
post #7 of 13 (permalink) Old Feb 16th, 11, 03:47 AM
I don't think it is VATS because if VATS was not satisfied with the correct key, the starter would not engaged.
Timing light shows spark where when starting?
Compression check shows?
post #8 of 13 (permalink) Old Feb 16th, 11, 06:34 AM Thread Starter
darrell
gonna re-chek spark w timing light and chek compression --will update this evening thanks i got many years exsperience but this one is kicking my rear
97Z4C is offline
post #9 of 13 (permalink) Old Feb 16th, 11, 08:28 PM Thread Starter
darrell
well got r done---tore the dist apart put it back in--repaired dist harness put it all back togethor and it still didnt start- spray fuel in throttle plates-didnt help-so i figured at this point , it wouldnt hurt to do the dirty deed-sprayed a big dose of starting fluid in throttle plates and it kicked off--it was on then -i knew where to go--i had another fuel rail with injectors , installed it and purred like a kitten ( my asumption was some of the old fuel got to the injectors and gummed them up and was getting too much fuel, seem like i would have seen firing in the exhaust
97Z4C is offline
post #10 of 13 (permalink) Old Feb 17th, 11, 03:13 AM
Good job, Darrell.
post #11 of 13 (permalink) Old Feb 17th, 11, 03:23 AM
prostreet69camaro's Avatar
Good job,,what a pain in the butt.
prostreet69camaro is offline
post #12 of 13 (permalink) Old Feb 18th, 11, 03:05 AM Thread Starter
darrell
thanks all--took her for my first cruz--now on to the little things like an a/c line, alt stop charging from setting -gonna be worth it i hope when summer comes and i drop the tops
97Z4C is offline
post #13 of 13 (permalink) Old Feb 18th, 11, 03:28 AM
Certainly will.
I suggest to take the A/C line to an Hydraulics/Pnuematic shop and have them replace the hose on your fittings and don't forget the O-rings from them also. Might be cheaper than buying the hose assembly from the auto store.
