blown fuse - Team Camaro Tech
New Member Introductions New here? Please introduce yourself.
post #1 of 4 (permalink) Old Apr 23rd, 11, 10:31 PM Thread Starter
TomC
blown fuse
my 68 blows the wiper fuse when you first turn the ign. key on even with the wiper switch in the off position. will even do it with motor unplugged
Tommytucker is offline
post #2 of 4 (permalink) Old Apr 24th, 11, 05:52 AM
Re: blown fuse
Unplug the switch as ignition voltage comes to the sw and sw applies a dash ground when wipers are turned on. If fuse stays, then bad switch or pinched wire.
Measure short to ground with ohmmeter.
Also, if electric choke is added and power is from the same source, or another electrical device is added to same circuit, fuse would need to be bigger as by design, fuse only handles wiper motor and washer pump.
Welcome to the Club, Tom. You'll be flogged for pictures, just an early warning. Correct year by the way.
post #3 of 4 (permalink) Old Apr 24th, 11, 08:49 AM
Jeff
yellow69RS's Avatar
Re: blown fuse
Don't know if 68 different from 69 but no power to 69 wiper switch. Sounds like a short in the wire to the wiper motor or additional accesorries added to the wiper circuit.
Jeff
yellow69RS is offline
post #4 of 4 (permalink) Old Apr 24th, 11, 09:15 AM
Jerry R.
jr68's Avatar
Re: blown fuse
welcome to welcome wagon
my Magnaflow X-pipe system sound clip, click the link
jr68 is offline
