transmission too high - Team Camaro Tech
New Member Introductions New here? Please introduce yourself.
post #1 of 5 (permalink) Old May 22nd, 11, 09:50 AM Thread Starter
steve
HI, I'm putting a 468 gen 5 BB in my 1969 camaro with a turbo 400. It was a small block 4 speed car so I have all new parts. The problem is that the transmission cross member puts the transmission too high. the valve covers ( stock) hit the wiper motor. the cross member is a Eckler's CM-3, that is the correct one if it is a CM-3. there is mo marking on it and the small block member is a CM-8. if it is a small block one will that make it sit too high?
gostinger is offline
post #2 of 5 (permalink) Old May 22nd, 11, 11:56 AM
Brandon
Re: transmission too high
Small block and big block cross members differ in that the big block member sets the tranny a bit to the right and the small block member sits the tranny in the middle.
Sounds more like the mount you've got is too high.
Brandon J. licence 1NASTY67
Nantooch is offline
post #3 of 5 (permalink) Old May 22nd, 11, 12:18 PM
Frame mounts (that mounts the motor to the frame) are different also! They set the motor about an inch to the passenger side.
Youngladd is offline
post #4 of 5 (permalink) Old May 22nd, 11, 12:56 PM Thread Starter
steve
I put the BB frame mounts that are 2-3/8 inches wide. taller on driver side. should be the right frame mounts and i got motor mounts thats are for BB and are 2-3/8 inches wide. I think all small block stuff is 2-5/8 wide.
post #5 of 5 (permalink) Old May 22nd, 11, 02:06 PM
Jerry R.
jr68's Avatar
welcome to the welcome wagon section
my Magnaflow X-pipe system sound clip, click the link
jr68 is offline
