Transmission slip yoke length - Team Camaro Tech
New Member Introductions New here? Please introduce yourself.
post #1 of 3 (permalink) Old Jun 27th, 11, 12:02 PM Thread Starter
Question Transmission slip yoke length
Hello
My 1st post.
I recently bought a Borg Warner super t10 transmission 3.42 (I believe) out of a 1980 Z28 Camaro,with 32 teeth on tail shaft, and also the rearend 3.08 gears, I think.
I am putting them in a 59 Chevy truck and I am in the process of trying to get a driveshaft , but need to know what the length is, the length of the slip yoke. that goes to the transmission so I can get it and determine the length of the driveshaft The guy I bought it from didn't have the yoke.
Please help, Thank you
dmh72249 is offline
post #2 of 3 (permalink) Old Jun 27th, 11, 01:50 PM
Hector
Re: Transmission slip yoke length
Well you need to get a yolk that will hopefully fit your driveshaft u joint setup... There are splicer u joints that will work but best if you match them up now... since your having the driveshaft worked on...
I was told when I did mine about two weeks ago.. Insert yolk all the way then pull out 1" and measure to flat of pinion yolk on differential.. And it should be measured with the weight of the car on the suspension...
68 Camaro Coup, BBC ,2457 headers, th400 , ford 9", Hotchkiss connectors,
Speedjester is offline
post #3 of 3 (permalink) Old Jun 28th, 11, 07:48 AM Thread Starter
Thanks for the reply, but my problem is I don't have a slip yoke and I need to find the right one that will fit in order to get a new drive shaft made. Sorry for the confusion.
dmh72249 is offline
