Ignition Problem Mystery - Team Camaro Tech
New Member Introductions New here? Please introduce yourself.
post #1 of 5 (permalink) Old Jul 14th, 11, 01:19 PM Thread Starter
Joe
This is my first time to the forum and I need some advice on an electrical problem with my 69 Camaro RS/SS convertible. When the starter clunked, I first replaced an old battery and then the starter and it continued to clunk. After jiggling the ignition switch with the key inserted, no starter sound.
Then I moved the steering wheel tilt up and ran my hands over the wiring harness on the steering column. Now the car starts.
I don't know what is wrong and I'm afraid to ride it.
Any clues as to my problem?
Joe Kono
Joe Kono is offline
post #2 of 5 (permalink) Old Jul 14th, 11, 04:25 PM
Re: Ignition Problem Mystery
Clunk isn't very descriptive - does it start? Clunk then start or Clunk and then nothing when you turn the key?
69 Pace Car and 69 Hard top
srode is offline
post #3 of 5 (permalink) Old Jul 14th, 11, 05:20 PM
69-Pace's Avatar
Welcome aboard Joe. You should post this question in the electrical forum since not everyone reads the welcome wagon. But sounds like you have a short / or broken wire in the column and the tilt either connects it or doesn't. Tilt original? so you have a 69? Its is a good idea every time you post to include details about your vehicle or include these in your signature. That way we can get to the marrow of your issue without ten post back and forth to discover this information.
You can buy a remote starter button at any decent auto parts source. These are used for tuning and testing and hook that direct to your starter. If you hit the remote starter button and the starter engages and sounds strong then your issue is in the ignition/steering wiring in the column.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #4 of 5 (permalink) Old Jul 14th, 11, 06:20 PM
Steps
on the top of the column is a wire rod that goes from the upper part down to a switch...?It is bloody sensive, the slightest tweeak and bend the wrong way or the switch mounted into its slotted mounting holes incorectly adkust causs intermitent issues
Its quite a few yrs since I ran into issues when rebuilding putting my column in ...so my description may not be 100% acruate, but bloody close.
As to the clunk..that should not relate to the above unless its partly or contactng few a split sec.
Jumpimg the connections from the batt lead on the back of the starter is a quick test to see if the solenoid is throwing/ the starter spins free and both together...use an old screw driver and dont let the sparks intimindate you.
Steptoe is offline
post #5 of 5 (permalink) Old Jul 14th, 11, 07:59 PM
Welcome from another southern central Texan.
Ron
The
An exercise in interchangeability on a Well optioned 67 SS 350 vert.
Geezer is offline
